speed_demon24
09-25-2005, 02:38 AM
I'm running street tires too. :( I powershifted 4th at 6500 RPM's today, and the RPM's never dropped below 6200 in 4th gear. :mad: Has anyone had any experience with the mcleod disk with the slp pressure plate and stock flywheel? And how does it drive, and what kind of power are you putting down with it?
wrd1972
09-25-2005, 08:15 AM
Might want to consider a Spec disk from LMperformance.
They go for around $150. Your pressure plate is the same as the Spec plate but you got the holes. Sounds like you need a stage 2 or 3. Dont know much about the Mcleod.
speed_demon24
09-25-2005, 12:08 PM
I've heard too many stories about the spec's breaking their springs, including my best friend when his car was just h/c, so its either mcleod, ram, ect...
96TurboTA
09-25-2005, 06:05 PM
Just wanted to add that I broke a Mcleod disk within 5k miles. Sometimes you just get a bad casting.
speed_demon24
09-26-2005, 12:19 PM
stage 4....no springs ;)
That's a little over kill for me. I need a good daily driver clutch, I drop in stop and go on the way to school every day. :(
