Reverse Rotation Verses Standard Rotation Water Pump??
masiroc566
09-24-2005, 04:56 PM
Hi...what is the significance of a reverse rotation water pump verses a standard rotation water pump serpentine set up? Does anyone know??
Dave89IROC
09-24-2005, 08:45 PM
all factory pure serp setups used a reverse rotation pump
you can tell by the back(flat, smooth) side of the belt drives the water pump pulley
in theory, the pump is cast slightly differently and has a reverse impeller in it, also, the reverse rotation pump has a slightly smaller bolt pattern for the pulley
respectirocz
09-24-2005, 11:25 PM
the theoretical benefit is that by allowing the coolant to flow to the heads before the remainder of the block, u can remove more heat from the combustion chamber
a cooler combustion chamber because u can run higher compression using the same gas
higher compression means more horsepower
1racerdude
09-25-2005, 12:03 AM
It depends how the belt is routed as to what pump ya use.Ya also have pumps for marine reverse rotation engines that are used in a dual engine boat to cancel the prop torque.
masiroc566
09-25-2005, 05:55 AM
Thanks for all your answers!! I was just wondering the significance behind the reversible one...that is the one I am using currently on my setup. Very informative!! Thx again!!!
Dave89IROC
09-25-2005, 08:34 AM
he asked about reverse rotation, not reverse flow
respectirocz
09-25-2005, 09:58 PM
haha, whoops
Dave89IROC
09-25-2005, 10:14 PM
haha, whoops
lol, happens to me too
