screech in left rear on left turn (help!)
jeff13
10-25-2002, 10:55 AM
:confused: After new brakes, new bearings, changed out stock rear end ...I still...can't figure out this metal on metal screeching only when I'm turning left fairly hard.
Thought if anyone was going to know where to go, what to try it would be you guys!!
Thanks for any suggestions.
LPEdave
10-25-2002, 02:21 PM
It's probably your brake caliper. Take a look at the diagnostics page in my sig...
Dave
jeff13
10-25-2002, 02:57 PM
:bow: Thanks a ton!
the problem was very similiar to what your Tech bulletin described. The new brakes were the not the original stock replacemant (done at a quicky place)and the tab was on the inside rubing ...but only as I turned causing it to get close enough to touch(apparently).
The new mechanic just called me after spending 2 hrs trying to diagnose it.
Moral of the story: Even seemingly simple jobs should be done by a pro!
