Cmr0z28
09-23-2005, 10:27 PM
My Pro Torque converter came with NO bolts. My trans builder told me the stock bolts wouldn't be strong enough, and I need grade 8.
I got grade 8 bolts from Discount Auto, but they're too long (bout 1/2"). The stock bolts fit fine, but if they're not strong enough, then that is not an option.
My trans install is tomorrow at 10am and I NEED these bolts by tomorrow morning!!!!
Where can I get grade 8 bolts in that size? Would NAPA have them??
Matt
Jazsun
09-23-2005, 10:33 PM
can't you cut the bolts down to the right size? Use a hacksaw or dremel.
Alvin@pcmforless.com
09-24-2005, 12:48 AM
the stock bolts should be a grade 8 or 9.8 (equivalent in metric) I'm pretty sure they are english threads so it will be grade 8.. distingished by 3 dashes on the head of the bolt
Severous01
09-24-2005, 01:30 AM
mine were grade 8. i just re-used stockers with my holeshot 2400 and 383 engine. i've had no problems with about 2k miles on it.
Cmr0z28
09-24-2005, 01:58 AM
Yeah I just cleaned up the stock bolts...they fit fine so I'm gonna re-use them. They're rated 9.8 Metric btw, which has a 130,000psi tensile strength. Grade 8 SAE has a 150,000 tensile strength, so it's strong, but not quite as strong as grade 8.
09-24-2005, 02:24 AM
its considered a equivalent in the engineering world.
LWillmann
09-24-2005, 08:18 AM
You could have also taken your stock bolts to Lowe's and probably found some grade 8 bolts that matched them. They sell all kinds of bolts.
30696bird
09-24-2005, 08:51 AM
I'm pretty sure I used my stock bolt too. It's been over a year and no problem yet.
Cmr0z28
09-24-2005, 09:23 AM
Thanks for the replies, I appreciate it! :)
snakethis69
09-24-2005, 12:07 PM
i just did my stall and reused the stock bolts
Jazsun
09-24-2005, 07:41 PM
or you could just cut the ones you already bought down! its not hard and will work perfectly as long as you dont ****up all the threads.
