Clutch Fork is toast.... (with pics)
lamb110
09-23-2005, 08:36 PM
well i've been asking you all about my slave cyl. and why i didnt have any pressure in my clutch pedal, it was a combination of things. When i pulled the Slave off the transmission the spring, rod and a bunch of other parts just fell out. I was happy to find out that it was what i expected, until i looked at the clutch fork (is that what you call the part that the slave cyl. presses against?). THe Fork was just totally snapped as you can see in the pics. My question is pretty stupid but will i need to pull the tranny to replace it? and were can i get one from? also could this have screwed up the tranny or clutch in any way?
thanks for all your help :)
Pics:
https://home.comcast.net/~lamb110/1.jpg
https://home.comcast.net/~lamb110/2.jpg
https://home.comcast.net/~lamb110/3.jpg
https://home.comcast.net/~lamb110/4.jpg
MR.ED
09-23-2005, 10:32 PM
I see your in dc! I am in baltimore..I have a used fork in very good condition. You can get it this weekend if you want being as your close! hows 25 bux sound? You can call my cell if youd like 410-320-2292 .Im not sure on r and r with the tranny in but I can look tomorrow I suppose. Unless someone allready knows!
wrd1972
09-24-2005, 02:58 PM
Wow, Is the push rod bent too. I have heard of this happening when the push rod is not propely re-inserted into the dimple on the fork. If its out of place the pushrod attempts to push the bell housing and thing explode.
I would condiser your problem a fluke.
lamb110
09-24-2005, 09:28 PM
i'll get pics of the push rod on mon. but from what i remembered the thing isnt bent it just exploded, the rod, spring and the housing it was in all were in seperate parts.
