LS1 DS yoke on LT1?
seawolf06
09-23-2005, 11:38 AM
Would a DS from an LS1 fit onto an LT1 yoke with an LT1 u-joint, or do you need an LS1 u-joint? I tried posting this question in an existing post, but the subject was misleading and no one answered. Thanks.
crazypurgatory
09-24-2005, 09:17 PM
The LS1 DS and the LT1 I believe are the same.
Look here. :)
http://www.tacreationsusa.com/other_rear_parts.htm
Chris G.
seawolf06
09-25-2005, 03:04 AM
it has different measurements for the 93-02 steel DS for T-56 and the aluminum DS for 98-02. the yoke length for the 93-02 steel is much longer. is this right? i thought the DS was the same no matter what tranny you had.
shoebox
09-25-2005, 08:22 AM
The complete driveshaft can be swapped without a problem as the overall length is practically the same. If you want to go swapping LS1 and LT1 front yokes, you might get into trouble as they are not the same length.
seawolf06
09-25-2005, 07:10 PM
that's what i was worried about. thanks shoebox, you're the man as always.
Bow94z
01-14-2007, 01:40 AM
so what has to be done to make the LS1 drivesahft fit on the LT1?
the LS1 shaft im lookin at is complete, so could i just swap the two?
seawolf06
01-14-2007, 01:51 AM
You can swap them directly as long as both are a one-piece shaft.
