95 Formula 6spd w/6.0L LS1 swap (FS/FT)
I need to reduce some debt so I wanted to see if there was any interest in this.
I have alot of pictures that I can email.....
1995 Firebird Formula
-black
-t-tops
-custom 6pt. chromoly cage (TIG welded)
-custom chromoly subframe connectors
-custom chromoly crossbrace with chromoly adjustable torque arm
-PA tubular K-frame (mild steel)
-PA tubular A-arms (mild steel)
-2004 6.0L LS1 shortblock, freshed 4000 miles ago with new rings/bearings
-TEA stage 1.5 5.3L heads w/hand finishing
-222/224 cam on a 115 LSA (idles like stock)
-Comp cams 987 valvesprings
-Comp cams Ti retainers
-Z06 injectors
-Z06 clutch
-2001 T56 tranny
-4.10 gears
-hooker longtubes w/Y-pipe
-Corsa catback (stainless)
-adj PHB
-boxed LCA's
-LS1 front brakes w/new rotors
-lowered 1.5"
-17" SS rims with brand new Nitto 555 tires (optional)
I am probably forgetting a few things. The car runs/drives like stock and is making around 380-400rwhp.
Exterior: The body is in good shape, never wrecked. Clean title. The front and rear bumper covers could use paint, but really not all that bad. Currently it is getting ~24mpg on the highway.
Interior: Near perfect condition. The cage/subframes/torque arm is about the nicest custom work I have seen....the bill alone on that was $3000. The AC is removed, but can be re-installed very easily. Heater box is still in the car, and there is NOTHING removed. Full interior, CD, speakers, heater/defrost, everything is still in place and working great.
$7200 w/16" wheels and tires
$7800 w/17" silver SS rims and new Nitto 555 tires (700 miles on them)
jhsformula@aol.com
Will entertain trades on nicer LT1 cars plus cash.
-black
-t-tops
-Z06 injectors
-Z06 clutch
-2001 T56 tranny
-4.10 gears
-adj PHB
-boxed LCA's
-lowered 1.5"
jhsformula@aol.com
Re: 95 Formula 6spd w/6.0L LS1 swap (FS/FT)
please send pictures to jmyzie@gmail.com
and would this car: http://www.cardomain.com/ride/715957 be considered a nicer lt1?
Jason, can you send pics to
studderin@aol.com
pleause.
What rear end is in the car? Any upgrade options.
Looking for a 98 GTP, stock or modded? in trade.
studderin@aol.com
pleause.
