99 trans am cranks but then dies!!!????
Old Sep 21, 2005 | 06:21 PM
saltydog's Avatar
my 99 trans am got water over the roof by katrina.
did all post flood things to save it.
but ever sense, it cranks and stays cranked for a little bit but then dies.
i found that if i squirt gas or throttle body cleaner directly in to the throttle body it stays cranked longer. i touched the throttle plate and it was ice cold is this normal.
obd2 scanner gave me a "tps/pedal position low input" code , what exactly does this mean.
i was also told that the passkey feature could have something to do with it.
i had similar probelms with my 94 formula a yr ago and there was a probelm with one of my ignition switch wires could this be the case with my 99 trans am.
PLEASE HELP!!!!!!!!!!!!!!!!!!!
Old Sep 22, 2005 | 01:28 AM
Z95m6's Avatar
Re: 99 trans am cranks but then dies!!!????
It sounds like you aren't getting fuel if it hits when you put gas in the intake.
Old Sep 22, 2005 | 12:57 PM
saltydog's Avatar
i checked fuel pressure and it is fine.
if its not getting fuel then why does it crank up at first.
would a few of the injectors being clogged cause it to die.
Old Sep 22, 2005 | 01:52 PM
Z95m6's Avatar
water in the fuel.
Old Sep 22, 2005 | 02:00 PM
saltydog's Avatar
no have already dropped the tank and cleaned it out
Old Sep 22, 2005 | 10:23 PM
69gto96z's Avatar
My LT1 does that sometimes to, it will crank up, and run up to about 600 rpm and then die off again.
Old Sep 22, 2005 | 10:30 PM
saltydog's Avatar
on a lt1 its most likely your ignition switch. or alarm causeing a probelm with your ignition switch.
i had the same probelm with my lt1 but cant get it fix on my ls1
Old Sep 22, 2005 | 10:35 PM
95HellBird's Avatar
I had the same problem with my car its a 95 had to put a new filter and fuel pump in it...works great, but i don't know about yours, sorry i am no help...ur sure its not the pump though?
Old Sep 22, 2005 | 10:58 PM
saltydog's Avatar
i am positive it is not the pump.
Old Sep 22, 2005 | 11:23 PM
Z95m6's Avatar
You aren't getting fuel. If it fires up when you put some flammable liquid in the intake that tells you its a fuel problem.
Old Sep 22, 2005 | 11:30 PM
saltydog's Avatar
it fires up with out the flammable liquid.
when i turn the key it fires up like normal for about 2 sec and then dies.
if i have my brother spray the flam liquid in it , it stays cranked.
i dont know if the computer is shuting it off , if its my ignition switch (like in my lt1) , or if it is gettin a constant flow of fuel to it.
do you think if the injectors were clogged could have something to do with it.
Old Sep 23, 2005 | 09:18 AM
69gto96z's Avatar
I meantioned it is happening on my LT1, but could my choke be sticking open when it doesn't need to be? Just something that crossed my mind. I am thinking about giving it a fresh tune-up this weekend though.
Old Sep 23, 2005 | 09:52 AM
saltydog's Avatar
i would try the ignition switch.
i found that if turned the key back and forth just right it would stay cranked.
but my 99 trans i cant get this to work.
Old Sep 23, 2005 | 02:06 PM
Z95m6's Avatar
It could be your Vats system. I don't know if yours is the same as an LT1 car but the vats system can shut down the fuel.
Old Sep 23, 2005 | 04:28 PM
saltydog's Avatar
what is the vats system. ive never heard of it
