ZDriver96
10-25-2002, 01:16 AM
Is the 1LE swaybar hallow or solid and How much lighter is it than the stock swaybar on an LT1?
Simple 1LE sway bar questionZDriver96 10-25-2002, 01:16 AM Is the 1LE swaybar hallow or solid and How much lighter is it than the stock swaybar on an LT1? LPEdave 10-25-2002, 01:33 AM The font 1LE is hollow, 32mm, and weighs 13lbs if my notes are correct. Since it's larger than the stock hollow bar, I suspect it's a touch heavier than stock, but not much. I don't happen to have the weight of the stock bar. The rear, I have less info on. The stock bar is 19mm hollow. In 1993, the 1LE was 21mm, solid, and weighed 10lbs. Later model 1LE's had a 19mm hollow bar, I don't know the weight. Dave | ||
