What to upgrade with 75 shot
Old Sep 14, 2005 | 11:35 AM
95patriotZ's Avatar
I can get a 75 shot Zex dry kit for dirt dirt cheap. What else would I have to upgrade besides spark plugs to very occasionally spray a 75 shot? Thanks guys
Old Sep 14, 2005 | 12:09 PM
Nitro Dave's Avatar
Re: What to upgrade with 75 shot
Sounds good,I would suggest a Window switch at the bare minimum. A bottle heater,purge and fuel pressure safety switch would help the system work to its full potential safely.
Dave
Old Sep 15, 2005 | 12:38 PM
95patriotZ's Avatar
well, im buying the kit used from a guy that i know. It is in real good shape and he is practically giving it away so I just want to know what else i would need if i go with this kit. It does have the purge valve and stuff like that. Also it is a type of kit you hoof up to your tps and it sprays when at WOT. Do I still need a window switch? I dont know anything about nitrous at all. I am assuming that the window switch lets it only spray from X rpm to X rpm, correct? Thanks for the info so far though. Im slowly learning.
Old Sep 15, 2005 | 02:06 PM
HarrisSpeedWorks's Avatar
I would still get a window switch. You are correct, the window switch will only let you spray from X RPM to X RPM.
Matt
Formula Steve
Sep 19, 2023 08:31 AM
13qtr
Oct 28, 2016 08:11 PM
Quickss96
Jan 29, 2016 05:56 PM
97SSdude
Aug 21, 2015 09:36 AM
NewsBot
Aug 3, 2015 02:40 PM
