If my car has Hal shocks/struts, will I need to buy any parts to return to stock?
BlackLT1_TX
09-12-2005, 01:28 AM
I have a set of stock shocks that are going to replace my Hals. I did not install the Hals, so I am not sure what all was modified and what I will need to return to stock.
Any ideas/part numbers :)?
-James
sssalah
09-12-2005, 03:00 AM
-James
Are the hals installed with the hal spring are stock type spring? You'll need the stock type springs to work with the stock struts.
OBE1 95Z28
09-12-2005, 10:40 AM
The stock spring sits in a support "cup" that is not used on the hal shocks with hal springs.
shoebox
09-12-2005, 11:50 AM
If you have modified stock spring seats (http://shbox.com/1/hal_seat.jpg) or no stock seats (none required with Hal springs), you will still need new stock seats to go back to the stock configuration.
1993-2002 front lower coil spring seat GM p/n 22099275
