Gripenfelter
10-24-2002, 03:06 PM
I'm doing the LS1 brake conversion.
Will a regular high grade bolt fit into the caliper to bolt it to the steering knuckle?
Anyone know what length I would need?
Gripenfelter
10-24-2002, 03:44 PM
How far into the caliper does the bolt go?
pkincy
10-25-2002, 02:06 AM
The best way to do this is buy the spindle, caliper, hubs, pads and line and line bracket from a boneyard. I got mine for $250 on ebay.
The rotors needed turning but a bud did that in autoshop for me.
Go buy the bolts from a GM dealer and you will be OK or test fit it and measure but use grade 8 bolts.
The trick is to use the ls1 lines and use the ls1 bracket also, otherwise you need to bend the lt1 bracket to make the lines flex properly.
