Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
12bolt moser install,, ran into problems..
Old Sep 10, 2005 | 04:08 PM
LEATHAL Z's Avatar
the housing is installed into the car, but i have ran into problems as far as installing the axle shafts. the brake caliper bracket does not fit over the wheel bearing, and the bearings have already been pressed onto the axles. and as far as the seals go, do they get pressed into the houseing before the axles go in or do they go in with the axles?? Pleas help!! thanks
Jessie
__________________
work in progress!
Old Sep 10, 2005 | 09:08 PM
IrocSS85's Avatar
Re: 12bolt moser install,, ran into problems..
yeah, the axles have to come back out and the bearings will have to come off. I believe the backing plates AND seals have to be on before the bearings can be pressed on. you should call scott K.
Old Sep 11, 2005 | 12:10 AM
LEATHAL Z's Avatar
ok thanks, but could you let me know how to get ahold of this guy. Thanks
Jessie
Old Sep 11, 2005 | 02:51 AM
1BAD86Z's Avatar
Jessie
586-630-1098, I can do it tomorow if needed.
Old Sep 11, 2005 | 02:52 AM
1BAD86Z's Avatar
Chris give me a call also, Drew still has yet to contact me and I have been call him.
Old Sep 11, 2005 | 10:10 AM
LEATHAL Z's Avatar
ok thanks, im taking the axle shafts to the shop today and getting the bearings pressed so i should be good to go after that, is anything else as far as putting in the seals? thanks for the helpful info, i hope to have it done today.
Jessie
Old Sep 11, 2005 | 11:55 AM
MotorCityNova572's Avatar
Jessie
if you have anymore problums with it.talk to Larry ( 1BadAir ) he has a 12 bolt moser...i know he has had a few problums with his...
Old Sep 12, 2005 | 05:46 PM
LEATHAL Z's Avatar
here are some pics on the whole car deal, im still not done.
Jessie http://community.webshots.com/user/zplayz69
Old Sep 12, 2005 | 05:48 PM
LEATHAL Z's Avatar
if that link does not work try this one
http://community.webshots.com/myphot...umID=447687683
Old Sep 12, 2005 | 06:52 PM
LEATHAL Z's Avatar
the first link will work, it just took some time to pass reveiw.
Jessie
Old Sep 13, 2005 | 08:45 AM
1BADAIR's Avatar
My brackets were on when I got mine, but yes the bearings have to come off.
Theonly problems I have had is the diff cover never stops leaking and having to cut the bmr TA bracket to get it to fit.
Old Sep 13, 2005 | 06:28 PM
LEATHAL Z's Avatar
ok thanks, the axles are at the machine shop so i should have them back by tomorrow.
Jessie
Old Sep 14, 2005 | 06:44 PM
LEATHAL Z's Avatar
axles are in,, thank god. its about time. thanks to everyone who provided me with the helpful info, i have pics posted up now so feel free. thanks once again.
Jessie
Nov 18, 2023 07:21 PM
Noenav
Mar 1, 2019 07:38 AM
ddr698
Jan 9, 2015 10:05 AM
tubby
Oct 13, 2003 09:16 AM
