12bolt moser install,, ran into problems..
Old Sep 10, 2005 | 02:13 PM
LEATHAL Z's Avatar
the housing is installed into the car, but i have ran into problems as far as installing the axle shafts. the brake caliper bracket does not fit over the wheel bearing, and the bearings have already been pressed onto the axles. and as far as the seals go, do they get pressed into the houseing before the axles go in or do they go in with the axles?? Pleas help!! thanks
Jessie
Old Sep 10, 2005 | 03:21 PM
LEATHAL Z's Avatar
Re: 12bolt moser install,, ran into problems..
any helpfull info would be greatly appreciated
Jessie
Old Sep 10, 2005 | 05:07 PM
Z95m6's Avatar
I think you are suppose to put the brake brackets on the axles then press the bearings on.
Old Sep 10, 2005 | 05:57 PM
94Sleeper's Avatar
That is correct. The Caliper Brackets need to installed onto the axel before pressing the bearings on. You will need to have the bearing pressed off. My 12 Bolt Moser came with instructions on how the caliper brackets were to be installed.
Nov 18, 2023 07:21 PM
Noenav
Mar 1, 2019 07:38 AM
ddr698
Jan 9, 2015 10:05 AM
tubby
Oct 13, 2003 09:16 AM
