conversion
realslow94z28
09-08-2005, 08:14 AM
can anyone convert this to standard 68kg/sec. flow rate on holeset hy35
SMOKNZ
09-08-2005, 08:31 AM
You want it in lbs/min or cfm?
realslow94z28
09-08-2005, 08:28 PM
Either One Will Do. Thanks
TA_LT1
09-08-2005, 09:16 PM
The HY35W is right for a 4cyl. I had a turbo 2.3L Mustang with that turbo. Some stock 5.0's can make close to 400 with them. I think they're too small for an LT1, unless you went with twins.
SMOKNZ
09-09-2005, 09:39 AM
68kg/sec = 8994.7 lbs/min No turbo I know of smaller than a house will flow that much air. Are you sure about the units... even if it would be Kg/min, it's 149 lbs/min, and that is alot of air for a turbo that's on a 4 banger. Thats more (WAY MORE) than a T-76, and you will probably never see one of those on a four cylinder. All I used is 1 lb = .4536 Kg, and converted sec's to mins. :confused:
realslow94z28
09-09-2005, 11:59 AM
i found out that it flow 800 cfms @ 3.0pr, and 700cfms @ 2.0pr. thanks for your help.
