93camaroLT1
09-06-2005, 02:54 PM
Looking to run the 150 shot, what are the best plugs to run for a 150 shot of nitrous?
-LE 1 heads (flow around 262/183@.600 lift)
-LT1 ported intake with 58mm throttle bores
-LE 1 cam (Mid 220s duration, over .570 lift, less than a 110 LSA, just to give you an idea)
-ARP head bolts
-ARP 7/16 rocker arm studs
-ARP polylocs
-Comp 5/16 flat pushrod style guideplates
- NGK TR6 plugs
-COMP chromoly pushrods
-CSR Electric waterpump
-3600 Vigilante converter
-3.73 gears, on 10 bolt
-Transgo Shift kit
-hypertech 160 degree termostat
-groty 1 3/4 long tube headers
-summit X-pipe kit
-BBK 58 mm TB
-1.6 Comp pro mag 7/16 Rocker arms
-SVO 42 lb/hr injectors
-MSD window switch
-Cold Fusion fuel pressure safety switch
-walbro 255 fuel pump
-B&M trans cooler
-LT4 KM
-MSD ignition Coil
-UMI Lower Control Arms
-UMI panhard bar
-Moroso cold air intake
-BFG drag radials
-Clevite H main bearings
-Clevite H rod bearings
-Clevite cam bearings
-ARP main bolts
-Total Seal file to fit, ductile iron piston rings
-Moroso high volume oil pump
-GM tall polished valve covers
-Cold Fusion Nitrous kit (150 SHOT)
Currently, I am using the NGK TR6 plugs, part number NGK4177, are these a good plus for a 150 shot? I'm prolly going to change those after I break in the motor before I go to dynotune, what plugs should I get if those aren't the best plugs to run with nitrous?
-ARP head bolts
-ARP polylocs
- NGK TR6 plugs
-Transgo Shift kit
-summit X-pipe kit
-BBK 58 mm TB
-MSD window switch
-B&M trans cooler
-LT4 KM
-MSD ignition Coil
-UMI panhard bar
-BFG drag radials
-ARP main bolts
