slayer6x6
09-05-2005, 10:54 PM
Does anyone know where to find the blockoff plates for the EGR and AIR system? The cheapest I can find are around $40-50 which I think is a total ripoff.
EGR AIR Blockoff Plates?slayer6x6 09-05-2005, 10:54 PM Does anyone know where to find the blockoff plates for the EGR and AIR system? The cheapest I can find are around $40-50 which I think is a total ripoff. SSpdDmon 09-05-2005, 11:47 PM www.ls1speed.com ? slayer6x6 09-06-2005, 12:07 AM $14 Sweet :thumb: blind527 09-06-2005, 12:08 AM As far as I know, there aren't AIR block off plates, just for the EGR. teke184 09-06-2005, 06:46 AM why wouldn't there be? check thunder racing too...not sure of the price Greed4Speed 09-06-2005, 02:16 PM Go to a hardware store, buy a small plate of alum or steel and make your own. It isn't difficult. Strahley 09-06-2005, 02:44 PM I bought mine from www.ls1speed.com Be sure to put some sort of gasket in with them, otherwise it will do you almost no good. I used a liquid RV type and it works perfectly mook99TA 11-24-2005, 04:16 AM nice myslowcamaro 11-24-2005, 10:27 AM i think tsp was $13, cant remember. ended up making a few myself mook99TA 11-25-2005, 04:19 AM do you have to delete any codes when you remove your air and egr provisions? myslowcamaro 11-25-2005, 12:14 PM do you have to delete any codes when you remove your air and egr provisions? yes Backfire4200 11-29-2005, 10:05 AM Go to a hardware store, buy a small plate of alum or steel and make your own. It isn't difficult. Yes, making block off plates is very easy. then disable the codes for EGR/AIR mook99TA 12-02-2005, 03:42 AM DO you need a scaner or an autotap to disable those codes? Backfire4200 12-04-2005, 08:29 PM DO you need a scaner or an autotap to disable those codes? yes, I use HPTuners. mook99TA 12-05-2005, 04:19 AM were can I get a HPTuners and how much is it? Backfire4200 12-05-2005, 08:54 AM were can I get a HPTuners and how much is it? http://hptuners.com It is full editing and scanning software. If you've never tuned a car before, it may be a little more than you need right away, but after you figure out what your doing, it's well worth it. :) Either way, you'll need editing software if you going to change DTC codes. (which is what you need to do for getting past the state inspection crap, EGR, AIR, etc) | ||
