FS: 60 gal compressor, brand new MIG welder
97firechicken
09-01-2005, 10:44 AM
compressor - $300
welder - $350 - never been plugged in
$600 for the pair.
PM for any info or send email whiteta97@sbcglobal.net
thanks
v7guy
09-06-2005, 02:27 PM
what kind of MIG welder, Lincoln, Hobart etc.?
how many amps, 115 volt?
What materials is is rated to weld?
is it already set up gas shielding?
97firechicken
09-06-2005, 03:24 PM
Lincoln Electric
Weld Pak 3200HD Wire Feed Welder
Model K2190-1
Got some serious welding chores? Then you're going to want a serious welder. Lincoln Electric's Weld-Pak 3200HD handles a huge spectrum of flux-cored or MIG welding jobs -- from auto-body repairs to farm fixes to around the home chores. You just can't buy a 120V welder with a more versatile range! The Weld-Pak 3200HD comes ready to weld mild steel with self-shielded flux-cored wire right out of the box. Also included is virtually everything you need to MIG weld mild steel. Just add a cylinder of shielding gas. Rounding out the package is a welding handshield, instructional video and undercarriage. The convenient mild steel procedure chart inside the wire access door guides you to all the appropriate welder settings for the job at hand. The Weld-Pak 3200HD has a 25-135 amp output and welds up to 5/16 In. steel using flux-cored wire. The unit plugs into a 120V (20 amp) outlet. It comes with a 3 year warranty on parts and labor (90 days warranty on gun and cable).
• Welds up to 5/16 In. steel
• 3-year warranty parts and labor (90 days gun and cable assembly)
• Output range 25-135 Amps DC
• Input voltage: 115 Volts
Store SKU # 599867
Internet # 166038
Catalog # 100093231
Price: $459.00/ea
want $350OBO NEVER BEEN USED, just taken out of the box to look at
97firechicken
09-14-2005, 09:00 AM
bump.
