AmericanMuscle33
08-30-2005, 01:10 AM
Ok, here's the deal...after about an hour of searching the forum I partially answered some of my questions, but would still like to get specific opinions.
OVERVIEW: my Car: bone stock LT1, 150,000+ miles, aggressive auburn carrier, more aggressive 4L60E, 4.10 Gm gears, strong driveline...trying to see what kind of times my tired Lt1 is capable of prior to engine rebuild...
Last time i went to the track i pulled a 13.9 + 98mph, with a 2.0 60'ft on balding craptaffic Kuhmo's...i was launching with Eibach Sportlines front and rear, and AGX's at stiffest setting...i was also breaking loose every 1-2 shift due to very aggressive shifts...a buddy of mine just brought me 2 M/T Slicks (28.0 x 9.0) mounted on 15 inch wheels. The tires are also bead-locked to the wheels via approx 8-10 screws on either side. He uses them on a built 1st gen that he drives maybe once a year...he said these tires and wheels were brand new 10yrs ago, and that he's put 2 passes on them since....they still look brand new...
I test fitted them today, lil rubbing...so i rolled both rear fenders...both tires now tuck...for track use I will be re-installing stock rear springs to raise ride heigth approx 1.5-2in in rear, and will be setting AGX's to softest setting in rear...
QUESTIONS: 1st: how much PSI can i run with these tires bead-locked? on one thread concerning a non-beadlocked M/t someone recommended starting at 16psi and working your way down.
That is my main question...as far as heating the tires, and launch technique, I've come to the conclusion from reading threads that its a case-by case basis, and is more of a feel it out yourself...see what works kinda deal...He requested i put not more than 5 passes on the tires, and to "not destroy them"...anyhow, whats worked for me in the past with my car on street tires is a healthy burnout, and stalling as high as i can, instead of flashing...
PLAN: i plan on warming up the tires, they've been sitting and need a good cleaning...perhaps 3-5 seconds of smoke, and roll out of it...i figure i'll start with 15psi (unless you guys say otherwise due to bead-locks), and will stall as high as i can...I've never launched with slicks before, and due to the small amount of runs i'm allowed, I'm going to try to find the breaking point of the tires in the first run if possible...I'm assuming high stall, pedal to the floor soon as i lift off brake will do the trick...if you guys have any other tips, or ideas, they'd be much appreciated...
All I really want is a couple tenth drop in 60'ft, and to hook during the 1-2 shift...if that happens, I'll be the proud owner of a Bone Stock LT1, with over 150,000 miles, that runs mid-13's...last time i showed up at my local track, the "new guy" running the Tech Inspection laughed at me when i told him my stock Lt1 runs sub 14's with the miles it shows....I intend on proving him horribly wrong...
Sorry for the longest post in my history of posting...Thanks,
