Does the Air Bag have a Secondary Power Source?
350350
08-29-2005, 05:55 PM
I have a '97 LT1/6spd car and my Son loves to ride shotgun with me. He also barfs his guts out if he rides in the back seat too long.
So I just pull the Air Bag fuse when he rides shotgun. But then I see the Air Bag light on the dash when the fuse is out and I wonder if there's a backup Power Source...
Anyone?
Dave89IROC
08-29-2005, 07:04 PM
not really, there is a internal capaciter, but generally, that lasts for 5-10 minutes max, the reason the light is just a failsafe type thing, letting the driver know of a problem(in this case, loss of power to the SIR module), the bags won't deploy if the fuse is out
Blue89Bird
08-29-2005, 07:14 PM
I'm pretty sure any dealer can install a manual passenger airbag cutoff switch. I know my Dodge Ram has one (since it doesn't have a rear seat)
ArcticHuggerZ
08-29-2005, 09:31 PM
I work as a GM technician. If you pull the airbag fuse out and the light comes on then the airbags won't deply. When the SDM (airbag control module) see a problem and turns on the light it won't deploy the airbags because it sees there is a problem in the system and it doesn't know if the problem could be something that relates to a bag or wiring,etc. So it just shuts the system down.
Lower
08-30-2005, 02:20 AM
Weird.
My Air Bag light was on, so I pulled the fuse.
Now the light doesn't come on.
And here you all say the light should remain on?
Guess I'd better get it looked at.
350350
08-30-2005, 07:25 AM
Cool... Sounds like the Little Man is safe in the Shotgun Position!!!
I called a dealer once about installing a passenger side cutoff, but they had no idea what I was talking about. However, I thought it was like federally mandated or something that they do it, and I only tried one place, so I'll try some more dealerships now that I live in a much much larger city with lots of dealers...
Thanks!
