Help w/ jet numbers ??
2fbodies2NV
08-28-2005, 10:18 PM
I just bought a used Compucar nitrous system from a friend. He bought it used at Carlisle and never used it. It has 7 jets. 26, 33, 37, 43, 46, 63, and 59 . 26 and 37 are installed in the nozzle now. How do the numbers work? I know the higher the # the bigger the hole, but how do you match them up? I'm totally new to this. Any help would be appreciated. Thanx, Chris.
LWillmann
08-29-2005, 04:15 PM
If you go here, and fill out the form, it will tell you how to match the jets up to get the power level you're looking for: http://www.robietherobot.com/NitrousJetCalculator.htm
2fbodies2NV
08-29-2005, 08:38 PM
I tried it, but the numbers don't match up. I'm guessing the numbers on the jets are thousandths of an inch ?
LWillmann
08-29-2005, 10:38 PM
Correct.. So if you enter .037 for the nitrous jet, you should see that a .020 fuel jet is called for, and should result in a ~50HP shot.
Upping the nitrous jet to .047 and the fuel jet to .026, you should see about 100 HP.
2fbodies2NV
09-07-2005, 08:49 PM
I don't have a 47.
LWillmann
09-07-2005, 11:14 PM
Well, with the .046 you should be really close to 100 HP. You'll just be a tiny bit richer than with the .047.
