Jeff Prock Lt-4 intake, direct port for 300-600 shot f/s
sniffin94
08-28-2005, 07:42 PM
Some of you guy's remember this intake it has still been never ran, comes with everything listed plus a brand new AS&M monoblade throttle body. I am chankging the entire direction my car is going and this intake t/b set-up won't work with the new block. Serious offers considered.
For Sale:
NEW NEVER USEDLT4 intake available that has been heavily modified and ported for max flow as well as setup to allow the use of the monoblade. The intake is custom plumbed using custom built nitrous bungs that have been welded to the intake manifold runners to allow the use of NOS Stainless Annullar nozzles
The nitrous setup was done by the top nitrous tunner in the country Jeff Prock at Applied Nitrous Technology. Intake also includes modified fuel rails to accept AN lines and assorted Earls fittings.
Parts and serves performed to the nitrous kit as follow:
NEW NEVER USED NOS Pro Race Fogger using Stainless Annular nozzles 25-600hp kit.
Kit has been custom plumbed and setup with purge.
Nitrous system has been flow tested and corrected for optimum power.
Precision lazer cut jets that have been flowed for accuracy.
NOS 15lb. HiFlow nitrous bottle with N20 psi gauge also #6 nitrous feed line.
Comes with three nitrous tuneups from Jeff Prock 200hp,250hp,300hp. These tuneups will also come with all information needed like fuel psi,timing to be used and so forth for each tuneup power level. Other tuneups available at different power levels.
This nitrous setup is a one of a kind and each of the tuneups listed above should actually produce 90hp over and above the listed hp levels above according to Jeff Prock.
Anyone that is very serious about making big power with nitrous and looking to step there system up to the next level of power and or considering a nitrous system and wants the most nitrous has to offer without the hassel of nitrous tunning guess work commonly associated with all other nitrous systems, then look no further because this is the setup to have that will produce power above all the rest gauranteed!
Just to give ya idea:
NOS Pro Race N20 system $999.00
New LT4 intake $250.00
Port Work $500.00
Applied Nitrous $1,500.00
Fuel Rails $100.00
pictures of intake
http://gmc.websitewelcome.com/~pbfbody/forum/showthread.php?t=2467
