More Cam questions
XKnightRider
10-23-2002, 07:42 PM
I have done searches, called a few places and seen the info on LS1 info.com
I have a bolt on 2002 SS and I am running N20. I want to do a cam and long tubes as my next mods.
What cam would you recommend for a mostly street driven car, with occasional track runs? Idle quality and emissions is not that much of a concern here in AZ. Also I want to stay with the stockk heads for now.
Thanks in advance.
JurisAg02
10-23-2002, 10:04 PM
Thunder racing 230 cam is superb with stock heads...not sure how it would do with N20.
XKnightRider
10-24-2002, 12:21 AM
Do you mean the 230/224 -111 LSA ?
Tucdog
10-25-2002, 01:43 PM
Take a look here, good way to compare.
http://ls1info.com/camstats/showdata.php
Taspeed
10-26-2002, 09:52 PM
How bout the F1 cam....makes pretty good HP with LT's..specs are .591/.569 230/226 112 LSA. Might also want to upgrade the valve train with this one while your at it though...Thunder racing has an install kit that includes all;)
white98LS1
10-26-2002, 10:39 PM
Im running the GTP Pig cam and love it, i didnt even drill out my TB, The cam idles awesome and i 2 am still running stock heads.
cam specs in my sig
JJ
XKnightRider
10-27-2002, 02:50 PM
Wow, that sounds like a cool cam. How much is it? Did you do the install yourself?
Thanks!
white98LS1
10-27-2002, 08:34 PM
if your talking about my PIG cam , its like $449
and i did the install myself. i however picked up the cam used for $200:D
2000redSS
10-27-2002, 11:17 PM
White98 you are laying down some sweet numbers man. Looks like I might need to think about that cam.
white98LS1
10-28-2002, 06:43 AM
This is a sweet Cam and ive heard of guys with a good set of heads shifting anywhere from 7k to 7400
im shifting right now at around 6300 thats with stock heads
Badass Idle (i havnt even drilled out my TB yet and the car has Yet to fall on its face)
JJ
