Jumping the AC compressor?
crAzy95z28
08-27-2005, 05:23 PM
on the relay what numbers do i put together to jump the AC compressor?
also all i have to do is touch them together and then turn the ac on and the compressor should start working right?
and i also can use a caot hanger wire or just a wire correct?
Randy
Dave89IROC
08-28-2005, 09:49 AM
jump pins 87 and 30 at the relay plug, a piece of wire will work ok, if for some reason it starts glowing, pull it out with pliers(will be hot)
94_Z28_guy
08-29-2005, 08:07 AM
Paperclip works well.
Kataklysm
08-29-2005, 09:01 AM
Why are you going to do this? You can damage wiring, its just letting all the voltage it can go through it. Circuits are not set up to hold as much voltage as you can put to them.
crAzy95z28
08-29-2005, 06:20 PM
well then why wont it come out without jumping the wires?
ive used new relays they still dont work!!
Dave89IROC
08-29-2005, 06:55 PM
if you are low on freon, it stops the relay from operating the compressor, as operating on a low charge will hurt the compressor
ArcticHuggerZ
08-29-2005, 09:37 PM
If the PCM sees that the compressor cycles on and off too much it can tell that it is low on freon and shuts the system down. Also if the signal wire going to the relay is bad the relay won't ever kit on , no matter how many good ones you put in there. The pins you are jumping is a battery voltage(power wire) and the power wire going to the compressor. There is a reason that no signal is going to the relay and you need to get that checked out. You don't want to cook that compressor clutch ..... money.
Kataklysm
08-29-2005, 10:42 PM
Please, it's not freon anymore. Freon was R12, we use R134A now. Yes I am anal and people won't change but it's like a pet peeve.
