scmudslinger
08-27-2005, 03:21 PM
I have a '93 Z28 w/ Automatic Transmission. Is there a good place to find out what the weight of it is?
Weight of my carscmudslinger 08-27-2005, 03:21 PM I have a '93 Z28 w/ Automatic Transmission. Is there a good place to find out what the weight of it is? jfischer 08-27-2005, 03:34 PM Roughly 3,400 pounds or so if I recall correctly. flatlander757 08-27-2005, 03:38 PM would a '94 be about the same? with all power options... Injuneer 08-27-2005, 03:45 PM Go to the bottom of this page for the "factory" weights, including some options: http://www.f-body.org/tech/tech.htm#FourthGen scmudslinger 08-27-2005, 04:31 PM Thanks for the help, guys 2000GTP 08-27-2005, 08:49 PM Go to the bottom of this page for the "factory" weights, including some options: http://www.f-body.org/tech/tech.htm#FourthGen That was a very helpful link, thank you as well. Johnnynsac 08-28-2005, 04:44 AM The only real way is to go weigh the car yourself. You can have two Camaro's with the exact same options and one might weight 100 pounds (give or take) more then the other. Thats GM for you. jfischer 08-28-2005, 10:36 AM The only real way is to go weigh the car yourself. You can have two Camaro's with the exact same options and one might weight 100 pounds (give or take) more then the other. Thats GM for you. Yeah, maybe if one had an empty gas tank and one was full :) Paul N 08-29-2005, 06:14 PM My 97 was 3408lbs with a half tank of gas, manual trans and loaded with t-tops. Weighed it on a truck scale a few weeks ago. FNDRB58 09-16-2005, 07:25 AM Camarosource.com has different numbers.... | ||
