wicked_95z
08-26-2005, 08:47 PM
I'm looking for a good head gasket for my 383 that will hold 14 lbs from a P-1SC. I did a search but didnt come up with anything useful that I could see. Thanks
Need a good head gasket for 14 lbswicked_95z 08-26-2005, 08:47 PM I'm looking for a good head gasket for my 383 that will hold 14 lbs from a P-1SC. I did a search but didnt come up with anything useful that I could see. Thanks breakmyfootoff 08-27-2005, 10:40 AM Fel-pro 1074 is about the best thing you can get without going to a copper or cometic. wicked_95z 08-27-2005, 12:34 PM I just want to make sure that I go through this one more time only. If that means copper so be it. Isn't the 1074 the stock replacement? If so that is what I had on there last time, granted my heads were slightly warped but still I want to do this only once. FutureZMan 08-27-2005, 01:02 PM Do it the right way the first time, go copper. wicked_95z 08-27-2005, 01:19 PM http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=502247&prmenbr=361 What do you guys think about this one? Jeff 96 SS 08-27-2005, 06:57 PM If its a street car don't go copper trust me I know! Go with Cometic if you only want to do it once. Jeff 96 SS BLOWN 96 TA 396 D1 Z8'S 08-27-2005, 07:03 PM I have always used Felpro 1074 never a problem ;) Lonnie Pavtis 08-27-2005, 07:18 PM The 1074 is a thinner LT4 style gasket. The stock LT1 gasket is thicker & made of weaker material... do not use these. You should be fine with a 1074 & studs. You will not see 14# from a P1SC either, unless you have stock heads & a small cam. Expect more like 10-11# max. rskrause 08-27-2005, 09:05 PM Avoid copper on a street car - they almost always seep. FelPro 1074 would be fine. The Cometic is an excellent gasket but to work properly the correct preparation of the head and block deck is essential - they must be straight, flat, and very smooth or the gasket will not seal properly. Rich wicked_95z 08-28-2005, 08:42 AM Is that what you use Rich? Would the gasket I posted above be a bad choice? It doesnt seem to be a copper gasket. rskrause 08-28-2005, 09:59 AM I've used both the Cometic and the FelPro. I have not used the Titan gasket. It sounds good, but of course that is their own description. AFAIK they don't make one for the LT1. Rich wicked_95z 08-28-2005, 12:53 PM Is the 1074 a stock replacement gasket that is sent with their gasket sets or is it a upgraded gasket? Thanks Geoff Chadwick 08-28-2005, 02:39 PM FWIW the "stock replacement" LT1 felpro is 9966PT and is $17.97 from advance auto parts. http://www.partsamerica.com/ProductDetail.aspx?mfrcode=FEL&mfrpartnumber=9966PT&parttype=100&ptset=A The 1074 OTOH is listed as "high performance" and will set you back $46.46 from advance auto parts. http://www.partsamerica.com/ProductDetail.aspx?mfrcode=FHP&mfrpartnumber=1074 The Cometic gasket I have heard wonderful things about when done right, but again - prep is key. If you search you will find that people have leaking problems because of the final surface finish of the head/block surfaces. If done right the Cometic will hold, but if its not right you are in for headaches for a while. No matter which you do though, good studs will make a huge difference. Some have stuck with bolts and paid the price, despite everything else done properly. FutureZMan 08-28-2005, 04:04 PM Avoid copper on a street car - they almost always seep. FelPro 1074 would be fine. The Cometic is an excellent gasket but to work properly the correct preparation of the head and block deck is essential - they must be straight, flat, and very smooth or the gasket will not seal properly. Rich I never had any issues with my copper, but i have heard of some. Guess i got lucky :D SloLt1Z 08-28-2005, 04:27 PM I use 1074's with studs with 15 psi and i have no problem with head gaskets. FutureZMan 08-28-2005, 05:22 PM I use 1074's with studs with 15 psi and i have no problem with head gaskets. How many miles so far? 94 NO TOP Z 08-29-2005, 10:05 AM I've had the cometics and studs for two years with no problems. Tuning is the biggest thing.. run lean or detonate and you'll blow out about anything you have. TravProcharged94Z 09-06-2005, 11:05 AM [QUOTE=Lonnie Pavtis] The stock LT1 gasket is thicker & made of weaker material... do not use these. You should be fine with a 1074 & studs./QUOTE] I just found out yesterday that i had the stock replacement head gasket on my car. I thought when we rebuilt it we used the 1074 but i was wrong. I was losing compression into the water jackets on the #2,#8 cylinder and the #1 was starting to do the same thing. What is the part# of the head studs? Thanks Travis TravProcharged94Z 09-09-2005, 11:17 PM Is this the part# for the head studs I need>>> ARP-134-4001 or ARP-234-4301? wicked_95z 09-10-2005, 08:52 AM I just called summit racing and ordered them. Dont remember the part number TravProcharged94Z 09-13-2005, 08:01 PM I just called summit racing and ordered them. Dont remember the part number Did you ever get your studs? If so could you give me the part#. Thanks :) Travis wicked_95z 09-18-2005, 09:44 PM That's what I was saying. I just told summit what I wanted when I ordered. Never looked up the part number TravProcharged94Z 09-20-2005, 03:11 PM Well what I was asking was for you to look on your invoice when you recieve them. It will have the part# on there, it should be one of the part#'s above. Thanks wicked_95z 09-20-2005, 07:51 PM Oh okay...well Ive got more bad news. I ordered mine a while back and they are already on the car and the invoice is gone. Sorry I wasnt very clear, I hadn't just ordered them. I simply told summit what I wanted when I placed the order mw 09-20-2005, 07:58 PM You trust Summit alot more than I do. Told them three times on the phone headers for a four wheel drive truck and still wound up getting them for a two wheel drive :) TravProcharged94Z 09-20-2005, 09:18 PM Oh okay...well Ive got more bad news. I ordered mine a while back and they are already on the car and the invoice is gone. Sorry I wasnt very clear, I hadn't just ordered them. I simply told summit what I wanted when I placed the order No biggie :) Thanks for the help anyways. SMOKNZ 09-21-2005, 09:36 AM http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=502247&prmenbr=361 What do you guys think about this one? Might be nice if it were for the LT1, looks like it's only for SBC's, the LT1 gaskets are a little different. | ||
