texasTA
08-25-2005, 03:13 PM
I have a solid-roller, fully forged (Callies Dragonslayer crank, Lunati Pro-Mod 5.85 rods, and JE forged pistons) 383 going in my 1994 Trans Am. The associated mods are:
TH-350
12-bolt with 3.73s
BMR tubular K-member, upper/lower A-Arms, SFCs, LCAs, PHR
Wolfe single Rear Drag Sway Bar, Torque Arm
Kooks 1 7/8 race headers with 3 1/2' collectors
true duals with dumps at the axle
fuel system setup to handle 1200hp (Jordon Musser's old fuel system)
17x9.5/17x11 Fikse FM5s with 335 dunlops out back
Baer Track kit
Corbeau a4 driver/passenger seat
battery relocated to trunk
Wolfe 6 point roll cage
I was originally going to go with a 350 direct port shot on top of this motor, hence the 10.5:1 compression ratio.
I have since kind of changed my mind and would like to go with a blower and nitrous on top of that, probably like a 150-200 shot.
Obviously to run a blower, I would need to get my compression ratio down. Someone said I could use some Cometic gaskets (real thick) which decrease the compression ratio a point and a half. This should bring me down to 9.0:1
Is that good enough?
My motor should make around 475rwhp through the a3 and 12-bolt I would like to make around 600-650rwhp with the blower and then spray the 150 shot on top of it at the track.
So what blower should I go with? I was thinking of the S-Trim. Would this be a good one to go with? Or is the ATI prochargers a lot better, and if so which one of those?
Thanks and if you need any other info, just ask
TH-350
12-bolt with 3.73s
Baer Track kit
