Shifting Problems After HPP3
Old Oct 23, 2002 | 04:09 PM
camaro98z28's Avatar
Unhappy Shifting Problems After HPP3
Ok I reset my Shift points with the HPP3 so I didnt keep hitting the rev limit of 6500rpm's. First to second is fine but Now 2nd to 3rd seems like its waiting to long to shift when I am floored. DAve remebers what it was doing. So I programmed it again and it still does the same thing . The car was fine before I changed it on Saturday!! Anyone know what I should do? Should I go back to stock settings and the start over?
Old Oct 23, 2002 | 05:05 PM
NEWBIE T/A's Avatar
Lightbulb I have never played w/ the shift settings, but ...
would suggest that you review your programming - perhaps you miskeyed the RPM's for the 2 - 3 shift.
If not, then try backing it back down bit by bit to see if it normalizes.
If it does not help, then it's :
Back to the Stock Programming !!
(Or, as it were.)
All I have played w/ is the shift firmness, which I now have set back to stock.
Good Luck !
Britt
Old Oct 23, 2002 | 06:22 PM
z top's Avatar
i had a similar problem when i did mine and ever since i increased the shift firmness and lowered the shift point it seems to be fine.
Magenta_Hearts
Mar 30, 2015 09:42 PM
BigWil
Mar 29, 2015 12:24 PM
jb4xx
Feb 2, 2015 10:00 PM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
