did i mess up the install?
LT1powered94
08-22-2005, 10:47 PM
I just put my new engine in. Now my tranny is slipping. It came out with the engine and was removed and installed twice. I think I put too much fluid in there, would that cause slipping? Its a stock a4. It ran well before the pull.
1SlowFormula
08-23-2005, 12:07 PM
Over filling the tranny has been known to cause slipping, even after the extra fluid has been removed. Trannys run off of pressure and there are a lot of pressure sensitive parts, by having too much fluid you add a lot more pressure and that can cause damage quickly.
When installing a tranny it is always better to put in a little less then what is required, run it for a few seconds, then top it off using the dipstick...
