sabre81
08-22-2005, 03:54 PM
Do this guy look primed? I think it is because it has a dull finish, but im not quite sure....
http://www.autosdepo.com/Part_Photo/JGS.jpg
is this primed?? - new front bumpersabre81 08-22-2005, 03:54 PM Do this guy look primed? I think it is because it has a dull finish, but im not quite sure.... http://www.autosdepo.com/Part_Photo/JGS.jpg Thanks dirtracer 08-22-2005, 09:34 PM it probably is. To check, use 600 grit and sand small spot. If your paper gets black residue (powder like) it's primed and finish sanding with 600. clean it and paint. RacingTiger04 08-23-2005, 01:03 AM its either primed or gel-coat.. gelcoat is usually a little shinier so im gonna guess primed :) 1-bad-z28 08-23-2005, 12:16 PM if it is a new front bumper cover, there should be a sticker on the inside saying original OEM primer was used. So to answer your question...yes, it is primed meissenation 08-25-2005, 08:29 AM It's an aftermarket piece of plastic, and as far as I noticed when I installed it, it's not primed. sabre81 08-25-2005, 09:56 PM It's an aftermarket piece of plastic, and as far as I noticed when I installed it, it's not primed. so you have one of these from this company. | ||
