New Clutch or rebuild?
Dtimekw
08-21-2005, 03:53 PM
I have a 95Z with the T56 six speed. The car is up on all fours right now. I am hearing a rattle from the tranny. The sound goes away when the clutch pedal is pressed in. This is the first time I heard this, but that doesnt mean it just happened either. It shifts fine most of the time, other times it is a little sticky, pump the clutch and sticky is gone. What do you guys think the rattle sound is? She has 118k right now and I don't have a history on last clutch etc.. I thought about just changing the clutch so I will have a new one, which leads to more questions. How hard is to do on four jack stands and a jack, second question, what kind of clutch is good? I don't go to the track, I don't think I pulling more than 300hp at the wheels, I like to jump on it thru town and on the highway. Any suggestions (besides don't speed, it's against the law LOL) Thanks for the help.
pugads650
11-03-2005, 09:02 PM
im having the same problem i wish i knew what it was
speed_demon24
11-03-2005, 09:22 PM
I have the same thing, I think it might be my throwout bearing, but I'm not sure. I'm about to put in a new clutch, but I'm not sure if I should spend the $$ on the throw-out bearing if thats not it...
NoRiceInside
11-06-2005, 07:06 PM
mine does it too. im sitting at idle and i take it outta gear, then let go of the clutch pedal. it sounds like a rod knock or something right?
well my mechanic friend told me its my throw-out bearing. ive been thinking about getting a new clutch to fix it, but its cheaper to get just the throw out bearing and see what happens after that.
oh and as far as difficulty...on jack stands about 1-2 feet off the ground...good luck.
mzgp5x
11-08-2005, 09:05 AM
Usually a 56 will have some noise. The way the gears are cut, and, the design. I have the same noise. Usually the noise will go away when a load is applied. During the time of load to no-load, you hear some gear noise. Typical of B_warner t56. Not much you can do.
