akafred
08-20-2005, 11:11 PM
what size tubing exhaust size tube would i need for 2 60-1 turbos on a 383. how much bigger should the down pipe be than the pipe from the header to turbos? would 2 1/2 from the header to the turbo be enough and then dual 2 1/2" exhaust or would dual 3" downpipes be reccomended ? the problem is i dont think i could fit dual 3" exhaust in the tunnel? mabey i can go to 2" after the cats
let me know what you think
thanks
97WS6SCharged
08-20-2005, 11:19 PM
If you're concerned with space, you may want to stick with a large single instead of the twins. On my S10, I have 3" pipe running off of each PT61. You really don't want to neck the pipe down if it can be helped. :)
akafred
08-27-2005, 07:59 PM
so what your saying i would need 3 inch tube going to and from each turbo?
or should i run 2 1/2" to each turbo than 3" down pipe from each turbo to possibly a single 4" mufflex or simalar or dual 3" exhaust
SMOKNZ
08-27-2005, 09:33 PM
Thats exactly what I did.
akafred
08-28-2005, 12:42 PM
what did you do 3" to and from
or 2 1/2 to and 3" from???
SMOKNZ
08-28-2005, 03:09 PM
I used a 3" collector, reduced it down to 2.5" then into the turbo's. Out of the turbo exhaust I used 3" to a y pipe and used a 4" mufflex system. On the compressor side I used 2.5 inch pipes to the intercooler, then a 3" to the throttle body. Hope it clears up some misconceptions.
Bill
akafred
08-28-2005, 04:44 PM
that is what i thought would be best as it might have a higer velocity going into the turbo with the 2 1/2 thanks
akafred
08-28-2005, 04:53 PM
do you have any pics of your setup??
SMOKNZ
08-28-2005, 06:59 PM
Yeah, I do, but my web page is down right now, I gotta get around to moving it to a different server... I can email you if ya want, let me know
Bill
akafred
08-29-2005, 07:34 PM
What all did you loose eg air p/s ect to make this work?
SMOKNZ
08-29-2005, 09:29 PM
Just air. Still have all the stock accessories. I used a 1LE pully and cut one of the ends off of it and turned it around backwards. I was able to sneek a 3" downpipe past that stuff!!
