DarkHorse
08-20-2005, 08:27 PM
Ok - on 93 and early 94's it seems the oil pressure sending unit is installed near the oil filter. My question is - I have a 94 and if it is NOT located near the filter is there at least a plug there that I can use for the Vortech fittings?
As it stands Vortech says to remove the sending unit and place it on their "T" fitting then screw the T fitting into where the sender was. I'm pretty sure that my sending unit is mounted on the back of my intake. Is there a plug that I can remove and still install the T near the oil filter? Or do I have to run Vortech's T fitting to the rear of my intake?
