eric9c1
08-19-2005, 11:44 PM
I have for sale a 2001 White Z28. It has 16,xxx miles currently on the clock.
Offer up your trades or cash.
2001 Z28, auto, power windows, drivers seat, doors, remote entry, bose CD
White with black top(hard top).
I am the second owner. Bought it at 12,8xx miles.
Mods:
MMS stage 2x 5.3L heads with rev duals, head studs
232/232 .600 113ls camshaft
TTS long tubes, 3" ypipe, 3" bullets, 3.5" dynomax catback (very high flowing and relatively quiet)
Ported Throttle Body, ASP, LID, EWP, MSD wires
Brand new 4L60E with shift kit, heavy duty sunshell, bands, input drum, pressure regulator, raybestos clutches, thicker retaining clip,
Vigilante 3600 Stall converter w/500 miles on it.
Trans cooler
Has TA Rear end girdle w/arp bolt kit
Meziere electronic water pump
Just replaced spark plugs with NGK TR55s, just changed the oil with Royal Purple and K&N oil filter, and transmission fluid and filter.
Dyno tuned by TAD from Race-Prep
Just put 2 brand new O2s in the car
4.10 gears
PA Tubular K-member
Rear Airbag
Parts Removed:
AC removed
Passanger airbag
Cruise control module
Air pump
Various heat shielding
The car is in excellent condition, there was at one point a roll cage in the car, and there are little slits in the carpet (2 of them) in the rear where the cage was installed, but not very noticeable. There is a light scratch on the car from the previous owner, but I don't even notice it.
Everything on the car works well.
I have a dyno sheet from LAPD in Chattsworth, CA that shows 431RWHP in full street trim. TAD From Race-Prep isn't completely finished tuning the car, which will be done in september at my cost(another 450$).
I am asking $16,000 or what you have to trade. Reason for selling is I'd really rather have the cash. I am about to get deployed to Iraq and would much rather not have to store the car and not have any payments while I am gone.
EDIT: Also comes with 2 skinnies with tires mounted, and currently has MT ET Street Radials on the back.
pics available upon request or here: http://www.ls1tech.com/forums/showthread.php?t=368284
Mods:
Trans cooler
4.10 gears
PA Tubular K-member
Rear Airbag
Parts Removed:
AC removed
Passanger airbag
Air pump
