How many mph do you pick up with slicks?
Old Oct 23, 2002 | 09:22 AM
LETHALRACER's Avatar
I went to the track last week and was kind of disapointed. I ran the 1/8 in 8.1@92 and 12.42@116.24 in the 1/4 on street radials. I could only give it about 40-50% in first. I would shift to second and go WOT and spin all over the place. I would let out hit third and mash it again. There was a guy there running 116 and getting 11.40's. I don't really care about the ET yet but my question is this.
If I put slicks on the car and could go WOT from beginning to end how many MPH do you guys thind I would pick up? A friend of mine was running 13.6@107. With ET streets he would run 12.54@110. He got three MPH on a relatively slow car. Have any of you guys experienced this problem?
Old Oct 23, 2002 | 10:10 AM
96blackbeast's Avatar
you should drop mph and gain alot of ET
Old Oct 23, 2002 | 12:57 PM
96z's Avatar
96z
What he said.
What was your 60'?
Old Oct 23, 2002 | 04:28 PM
My 60ft times are in the 2.03-2.05 range. How do you guys figure that the mph will go down? That is like saying giving half throttle on the dyno will yield more hp. If you can only give it 50% in first and spin second, let out then hit third, how can I loose mph when I can hammer it from the get go?
Old Oct 23, 2002 | 05:41 PM
Kreinmc's Avatar
You will probably gain 3-4 mph. I don't see why some of these guys have it in there head that a better 60' will make the mph go down
Old Oct 23, 2002 | 07:22 PM
mongse_1's Avatar
Because every person I know that has switched from Nittos to ET Streets has lost MPH but gained ET.
I gained a LOT of ET, but held pretty even on trap. This was on a blower car though and temperature would've made a big difference.
Old Oct 23, 2002 | 07:36 PM
96z's Avatar
96z
With a better 60' your mph should go up because your in effect slingshoting your car.
In general with ET Streets you have more traction ie. more friction and grabbing so your MPH should go down a little.
Old Oct 28, 2002 | 03:08 PM
35thanniv.SS's Avatar
Using slicks wont really change your mph. Mph is related to hp. Using sticky tires will allow u to hook up better, thus lowering ET times.
Old Oct 28, 2002 | 05:58 PM
gb95zconv's Avatar
From what Ive seen MPH usually goes down alittle. The way I think of it is this.....your average speed over the 1/4 is faster allowing you to reach the trap in less time even with a slower top speed. So its your average speed that sees the improvment giving you a lower ET but not nessisarily a higher ending trap speed.
Old Oct 28, 2002 | 06:27 PM
sfGi8nt's Avatar
If your 116 isn't the FULL potential MPH in your setup, then maybe there is something to gain.
But if 116 is the MAX you can get with a great short time and all, then going to Streets isn't gonna get you much..if anything at all.
I lost a mph when I went from street tires to BFG DR's! With my 60's dropping a tenth
Old Oct 28, 2002 | 08:29 PM
Luna's Avatar
Speed drops due to greater friction, getting up to speed faster and usually greater diameter.
Old Oct 29, 2002 | 04:46 PM
CANTONRACER's Avatar
I lost over 1 MPH switching from stock radials to BFG DR's.
The only reason someone were to gain MPH with slicks would simply be because the car was unable to hook whatsoever.
But for most, you lose MPH, no sidewall and the tires absorb hp. What works for great traction does not work for the topend.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
4586
Apr 29, 2015 01:43 PM
Camaro90RS
Jul 23, 2002 07:57 AM
