catsnet
08-15-2005, 08:14 PM
Ok - Let’s start :D
Had an overnight installation a couple of days ago and here is what happened...
First, about the whole system...
From the head unit - 2 sets of RCA's (good ones)
From the battery - 4ga, goes through the fuse and 2 way splitter in the trunk, splits to 2 - 8GA,
One 8Ga goes trough cap to the bigger amp to the sub in the rear wing...
Second directly to the smaller amp - to 2 bridges to components in Q-boxes in front.
All grounds are 8ga wires
Now all the crappy things what happed that I need your advice on...
1. "The main one" - left component worked for maybe 2 seconds. The fuse in the amp went but didn't brake. So I took out the pair of pliers and put another one in. same thing happened. Well - I had to make sure and got the pliers in there for the third time :D - this time was the charm. One of the bridges exploded with the cover flying away and a good pile of smock coming out of it.. :cry:
Oh yea - the other speaker/tweeter works just fine.
Question: are this bridges inputs polar sensitive?? What else could go wrong in there? since I only want to get just a pair of bridges (I hope all of them work with different brands), I really don’t want to fry it too.. What the "step by step" troubleshot I have to do
2. Who ever put the Q-Logic boxes on the kick panels probably know that the fitment is a real $hit and to get them to hold in there with 300W components in them is a real PITA.
Question: want did you guys do to get it to hold in the far end on the passenger side.
I’ve but as much cotton in there as I could to kill the resonation but its still craps out like a broken guitar...
Also another quick question - my Cap has 2 ports for the ground. One of them goes to the frame ground and the other one is free for now.. Can I use it as the ground for one of the amps??
Thanks to all in advance
All the inputs will be appreciated
Alex
Alex
