F/S White/Ebony 96 6Spd T/A,Huge mod List
LT1iFiEd
08-15-2005, 11:21 AM
Ok so heres the run down on the car ,this car has been my pride and joy for the last three years,but now Im forced to sell due to finances.The car is a CLEAN Great condition,inside and out,no tears on the leather!1996 Pontiac Trans Am ,Clean title and clean carfax,T-Tops,All factory CD stereo with Un Blown speakers,8X,XXX miles(80k)6speed car,with every option!!The car is Artic white with Ebony Leather insides.Every option being eveything you can possibly get in a T/A it has,except WS6 Pkg.The story on the car is I blew up the shortblock recently And I dont have the time or money to repair as Of now.It has a hole in Cyl 7's Piston,And it didnt hurt the block,Head might be able to be saved.U can either replace the shortblock,or replace a piston,motor is torn down as of now.Compression on all the other cyl were 175 psi across the bored.
Here are the mods on the car:
Stock shortblock
Ported Stg 1 heads by CRE With aftermarket 1.56 1.94 valves,No I Dont have the flow sheets unfortunately.
Ported intake manifold.EGR Block offs
Comp cams Custom Grind N20 Cam Duration 224/238 Lift 532/549 on a 112lsa
Comp cams 1.6 NSA Pro mag 1.6 RR's
Comp cams 987 valve springs
Comp cams hardend Pushrods
Comp cams seat,retainers and locks
Non coated Hooker super comp LT's 1 5/8th
Hooker 3" Y-Pipe
Custom 3" exhaust all the wat back through a 3" DynaMax Race Bullet with SLP Dual/Dual Chrome tips.
Aluminum Driveshaft
T/A girdle
Motive 3.73's
Torsen Posi
Tubular BMR LCA's
EMS Strut tower brace
The Chrome 16" stars with 245/50/16 Kuhmo's up fromt W/85% thread left and rears have 245/50/16 Nitto Dr's W/75% thread left
iRotors crossed Drilled and Slotted rotors Fronts
LT4 Km
160 Deg thermostat
Unlimited Tuning By Bryan @ PCM4less(OBD 1 Conversion)
Spec stg 3 Clutch
Hurst Proshifter with shortstick
Delteq Coil Pack Conversion kit,Valve cover mounted W/Delteq Custom length 9mm Wires.
Edelbrock Chrome Valve covers
Clear corners
BBk 52mm TB
FMS 30lb injectors
Vortec elbow Plummed for N20(Sprayed only 1 bottle thru out whole motor)
A/F Ratio Phantom gauge the single pod
Manual fan switches
Moroso Cold air intake
Ported MAF
Tinted windows
Walbro 255 Fuel Pump
Lakewood PHR
Meziere HD electric water pump
Etc...To much to list!
With this Setup N/a The car putdown 377Rwhp 373 Rwtq I do Have the dynosheets and the car ran at the track a few times and I was able to get 12.51 @ 116 with a 2.1 60ft.
I'll sell the car for $4,000 with all the mods or $3,000 with out all mods(If u buy the car W/O the mods I'll leave the mods that the car needs to roll,rear end,susp. clutch ,etc..Car can be delivered locally free of charge,within 50 miles,Any farther buyer pays/arranges pick up.
Pm for n e questions or for pics.
Thanx for looking.
new_z
08-15-2005, 09:04 PM
sounds like a bad ass car! something like i need. i have a 97Z but its mostly stock.. just bolt ons. im about to put a 383/396 short block in it. the car runs fine about the do a good ole tune up and give it some paint. i have a few pics. curious if you want to do some sort of trade? i am in iraq ill be home in a month... i also have a 99 cbr f4 i could trade ya.... lemme know what youre thinking here. send me as many pics as possible!!! michael.mastej@blab.centaf.af.mil
ill be back to Eglin ( near p-cola/panama) in less than a month........
70ss
08-15-2005, 10:22 PM
Please email pics to 70ss (r_dash@charter.net)
