TravProcharged94Z
08-12-2005, 04:51 PM
A guy i know is wanting to run a 250 shot on an LS1 car. Would the stock intank pump and a walbro inline suffice?
Fuel Pump.TravProcharged94Z 08-12-2005, 04:51 PM A guy i know is wanting to run a 250 shot on an LS1 car. Would the stock intank pump and a walbro inline suffice? Thanks HarrisSpeedWorks 08-12-2005, 05:06 PM What other mods does he have? Heads/cam? With a Racetronix kit on a LS1 car you can make right around 600 RWHP before the fuel pressure regulator becomes an issue. If you remove the factory FPR and re-locate it to the fuel rail you can support right around 650 ish. I would not suggest the inline pump; it's just a band aid. It can help to keep pressure to some degree, but in all honesty it isn't needed with a fuel system that is properly set up. Now if you're looking for a solution for over 650 RWHP I would start looking at an external fuel pump. Matt A guy i know is wanting to run a 250 shot on an LS1 car. Would the stock intank pump and a walbro inline suffice? Thanks TravProcharged94Z 08-14-2005, 08:36 PM I was mistaken, he's only wanting to run a 200 shot. The car has all the bolts and a cam. It put down 406hp N/A. HarrisSpeedWorks 08-14-2005, 11:48 PM Your friend should really look into a new in tank pump. He’s looking at more then 600 RWHP and an inline pump is really pushing it at that power level. Matt Nitro Dave 08-15-2005, 09:51 AM If he needs a system that he can grow further with Tell him to check out our dedictaed fuel system. Dave | ||
