viper03af
08-11-2005, 07:24 PM
i need few fast/correct anwser's
i installed the walbro and when i prime it the fuel psi falls from 45 to like 12 really fast......... is that normal ?
i have the corrigated hose and such and it has 2 clamps on the top and the pump was one tight so i only used one clamp
when motor is running or under boost the fuel PSI stays vary steady? 46 at idle
this is a v6 but same should apply
