blackz151
08-11-2005, 09:52 AM
i am in the process of building a 355 for like a 250 shot. Now i am at the point of picking out a cam. witch cam should i use. i was looking at the nitrous cam from comp cams.
dur.
268/286
lift
.477/.490
and other ideas i am tryin to get the best cam so i dont have to change it down the road
NVetro
08-11-2005, 06:06 PM
Problem with nitrous cams, and its been proven time and time agian with dyno charts on this board is they are GREAT with n2o, BUT when it comes to N/A, they will make less power and obviously dyno less then most people would like. Talk to Bret Bauer (SStrokerace), he can make a custom grind cam for ya, I went with him for my 383 setup. Shoot him a PM or something, you'll thank yourself later, he has a god brain to pick also :)
Nitro Dave
08-11-2005, 06:47 PM
I second getting a custom grind cam.Off the shelf cams are ok.But for the best results a custom grind normaly complements your setup.I use Laser cams.Bill has always done a great job for us.
Dave
slomarao
08-11-2005, 11:34 PM
How much are you going to use n20? If you plan on using it whenever you race you should get a nitrous grind. Otherwise you should get a NA cam and keep it on 114.
blackz151
08-12-2005, 12:19 AM
i am gonna use it when i go to the track like twice a month and like when i playin around with some imports around here
NVetro
08-12-2005, 09:01 AM
Yea, then def get a custom grind. They arn't much more $$ either.
