Leaky NX fuel solenoid?
Black1995Z
08-10-2005, 02:05 AM
Well, I had a fuel leak and noticed fuel in the oil.
I didnt see any signs of leaky injectors or fuel pressure regulator. But fuel is still gettin in the oil somehow.
I pulled the rail and now have another set of injectors and a spare regulator with 2x more miles on them and I realized I didnt test the fuel soleniod for leaks. Now im reluctant to switch to the old fpr/injectors. What should I do? Is this possible/common?
Is there a way to test the fuel solenoid for leaks with the fuel rail disconected? :(
NXRicky
08-10-2005, 02:15 PM
Yes you can use air at the same fuel pressure as your car... Take a good look at your solenoid.. Make sure the inlet is on the -4 hose connecting to the rail.
Ricky
