Zero_to_69
08-06-2005, 10:01 AM
Hi All, I'm helping a friend diagnose his new turbo setup.
We're dealing with a 1998 Grand Prix GTP which is all stock, except for the
recent addition of:
- Turbo 17 PSI
- Intercooler
- 1.9:1 Ratio Rockers
The engine has a 2 Bar MAP sensor. When the engine runs under full boost,
I am speculating that the stock MAP sensor is not able to read the manifold
pressure properly.
As I understand it, the sensor has a range of two Bar from a reference
point.
IE: - 1 Bar to + 1 Bar
Approximate Elevatoin 1100 ft.
= ~ 0.94 Bar (~28.6 in./Hg. )
MAP at idle = ~ 10 in./Hg.
Gauge Reading = ~ 18.6 in./Hg.
With the engine off and key on, the MAP is reading pressure at our current
elevation which is apporximately ~ 14.2 PSI (~ 28.6 in./Hg.)
So...would 14.5 PSI be considered zero as the reference point of the MAP sensor with a range of 0 PSI to ~ 29 PSI?
or
Does the sensor reference begin at zero PSI with a range of - 15 PSI to + 15 PSI?
If the latter is true, will he max out the MAP sensor and default to Speed Density Mode?
Thanks...and sorry the "math" ! :cool:
recent addition of:
- Turbo 17 PSI
- Intercooler
pressure properly.
point.
or
