Wiring up choke.
'86 350
08-04-2005, 09:20 PM
I got a new Edelbrock perfromer carb and I need to wire up the electric choke. I know I have to ground the negative, but what should I hook the positive up to?
TraceZ
08-05-2005, 02:05 AM
switched ignition.
'86 350
08-05-2005, 08:58 AM
What?
TraceZ
08-05-2005, 09:16 AM
What?
You hook the positive up to switched ignition. Switched ignition is +12 volts with the key on.
IRONFIST
08-05-2005, 11:55 AM
Yep, don't hook it up to a straight source that stays on... or your choke will always be on.
'86 350
08-13-2005, 02:01 PM
Okay, so I just hook it up to anyhting that goes on when the key is only in the "on" position? Can someone give me an example?
Thanks. :)
TraceZ
08-14-2005, 01:25 AM
Thanks. :)
The + lead to your coil is +12v ignition. You can also look at your fuse block, it will have a couple spots on it to plug in additional circuits. they are labeled 'ign'.
