Nitro Dave
08-04-2005, 03:24 PM
Group 1
OK guys due to the responce we got last time we have brought back the dual nozzle special.
This system comes complete with.
1.Your choice in white or Black Bottle.(The Bottles will have NXs NEW 45 degree Valve)
2.Dual Shark Nozzles
3.High Flow Ys(because Ts are restrictive)
4.Blow Down Tube and NHRA Blow Off Fitting.
5.Liquid Filled Nitrous Pressure Gauge.
6.Iceman Pure Flow Solenoids (LIFE TIME WARRENTY)
7.Jetting From 100 to 300 Horse Power.
8.All lines,Fittings,micro switch,wiring harness and relay etc.
To top this all off we are giving you a free replacement Bellow too put your dual nozzles in.The Shark Nozzles come with adapter nut fittings that will firmly fasten the nozzles to the bellows.The bellows has no holes in it.All you have to do is drill two small holes where you like them.Place the nozzles and go.
This system has the best of the best.No fitment issues!!!! No headaches to make it fit!!! This is one of the best deals we have put together..
This complete system is going for 599.99. :) With this system we GIVE you for FREE a new smooth bellows (50.00 Value) :eek2: If you are a LT! or Corvette guy subtract 50.00 for the smbellows since you will not need it.
http://img160.echo.cx/img160/6446/davesdualnozzthunder5ha.jpg (http://www.imageshack.us)
Group 2
OK guys we have taking the standard maff kit and changed it up.Here is what it comes with.
1.Black 10lb bottle with NXs new 45 degree valve
2.WOT instead of the TPS switch
3.Nitrous Discharged Maff ends
4.Blow Down Tube and NHRA Valve
6.Iceman Pure Flow Solenoids (Life Time Warrenty)
7.Jetting From 50 to 150 Horse Power
All this for only 799.00.... WARNING...There are only a limited supply of these systems available.If this system is the one for you I suggest placing your order as soon as possible.Once all the ones available are gone it could be up to one month before we can fill the remaining orders.
Picture Comming soon......
Group 3
With the purchase of a Nitrous Express Maximizer recieve a FREE heater transducer and remote bottle opener controll module...Thats a 170.00 in free value all this for only 640.00
You can call in your at 1-866-648-7637.
Thank You for your support.
Dave
Group 2
Group 3
Dave
