Any of you engineering types also a mathamagician? (Also paging Rich)
LameRandomName
08-03-2005, 09:45 PM
This is sort of car related. Technically. Barely.
It's definitely advanced tech though, because I don't think the guys in the other forums could even manage a quadratic equation, let alone
I was watching Mythbusters and they were working on the whole; "Will a tissue box hitting the back of your head at 60mph kill you?" question.
I don't have a fancy test rig, but I do have a pencil, paper and a kitchen scale.
Here's where I'm at:
863.76 Kilogram-Meters/Second
Now I'm stuck.
I don't know how to convert that into a unit of energy that I can understand in terms of physiological consequences.
Also... Rich...?
This is where you come in.
As a medical professional, I figure you would be in a position to judge the potenial carnage.
OldSStroker
08-03-2005, 11:48 PM
I'm a little confused with your 863.76 Kilogram-Meters/Second figure. A box of 160 Kleenex tissues has a mass of 268 gm +/- a couple. 60 mph is about 26.82 m/sec. Linear momentum is m * v or mass times velocity. I get (.268 Kg* 26.82 M/sec) = 7.188 Kg-M/sec. You got 120 times as much. Hmmmm... Even if you used a larger box of tissues of 322 gm., you would still be 10^2 or 100 times the momentum. Either I don't understand the concept or one of us is a couple orders of magnitude off.
To assess the damage caused by a collision we look at the force caused by the change of momentum of the tissue box. IOW, assume it decelerates from 60 mph to 0 when it strikes the noggin. This can be called the impulse-momentum theory and is equivalent to Newton's Second Law.
Before we get into numbers, we need to know about how long it takes to decelerate the tissue box. If it were basically uncrushable (a brick), it would decelerate in the distance it penetrated the skull, let's say 25.4 mm (1 inch). If the box crushed completely, it would be about 254 mm or ten times as much. The analogy is hitting an imovable object with an M1 Abrams tank that doesn't crush much, and hitting it with you car which crushes a number of feet assuming a 60 mph impact. Much more force is transferred to the occupant (or the bridge abutment aka your head in your example) in the short time it takes the object to travel one inch than if it takes 10 inches to stop it. Personally I think they chose a tissue box just because it will crush in a 60 mph impact.
We can use the impulse approximation if we assume that the force of the flying snotrag box acts on the head for a short time but is much larger that any other force present. That's probably an ok assumption. It's travelling at 26.82 * 1000 = 26820 mm/second. With a constant deceleration in 254 mm (length of box), it might take about 19 milleseconds to stop. (26820+ 0)/2 = 13410 mm/sec avg. velocity / 254 mm = 52.79 1/sec or .0189 seconds.
Using Issac's 2nd Law, change in Momentum(delta p) = F/change in time (delta t), we get F= delta p/delta t or 7.188/.0189 = 380.3 Kg-M/sec^2.
Again using F=Ma, solving for acceleratuion we get a = F/M. If the average noggin has a mass of about 6.8 Kg, we get a = 380.3 Kg-M/sec^2/6.8 Kg or 55.92 M/sec^2. Dividing by 9/8 M/sec^2 (1 g) we get about 5.7 g's. applied for 19 ms. Now unless my numbers are way off (by a factor of 10-20), that g load for that time isn't anywhere near lethal. Here's where Rich needs to make a call.
FWIW, 100-120 times that figure or 570-684 g's has a P sub k (Probability of Kill) well over 1.0. IOW, you be dead many times over.
Someone needs to check my math (and also physics), but my conclusion is NO, the 60 mph impact from a standard Kleenex box probably won't do you in, but it will sting a lot.
My $.02.
MachinistOne
08-04-2005, 03:45 AM
Basically a box of tissue does not weigh as much a a baseball, and a baseball will concentrate it's mass behind a smaller point of impact causing more damage because the load is not spread out as much on your dome. If pitchers can hit guys in the forehead or somewhere where the helmet doesnt cover at more that 80mph without death, then I doubt a kleenex box will cause you to hemmorage and die.
A good place to look for this kind of information is helmet manufacturers, to be snell and DOT approved, they have to test all sorts of impacts and their effects...their was a real intresting article in last months hot bikes that talked about the rating given to head impacts and how much actual force it takes to cause a life threatening injury.
LameRandomName
08-04-2005, 09:25 AM
My box of tissue was 366grams.
You know, this question seemed a whole lot less silly last night...
OldSStroker
08-04-2005, 11:18 AM
Yeah, didn't it. I still think your momenmtum is way off.
It's been many many years since I worked with head impact studies, but if I recall the damage depends on a combination of gs and time. The head can withstand lots of gs for a millesecond (.001 sec), but as the duration increases, the max g drops off rapidly. I'm sure that data is available on-line, but we've probably wasted enough bandwidth on this already. :)
Now I know why I don't watch those shows.
Zero_to_69
08-04-2005, 03:46 PM
Wait, I want to waste more bandwidth on this one!
I'm trying to picture a scenario where a tissue box would be moving at 60 MPH
to begin with (waiting for the, "in your car response").
Aside from that, even if the box was traveling at 60 MPH, I would imagine the
rate of deceleration after removing "the power source" is going to be huge.
There just isn't enough mass to cut through the air (consdering surface area
of any side of the box)...or even keep the box directional for a decent distance.
So...by adding some spoilers/air foils, a 'fast back' style box end, and cone shape front end, we could really make this tissue a killer. :D
OldSStroker
08-04-2005, 04:09 PM
Zero, imagine it falling from a 4th or 5th story dorm window. Ma Nature supplies the constant power source. One could run an interesting experiment to measure vertical velocity and even terminal velocity if the building was high enough. You could even measure the impulse when it hit the ground.
Or Scotty might rig up a tiny impulse engine for it. ;)
Think "out of the box"!
Pun was intended.
rskrause
08-04-2005, 04:13 PM
I very much doubt a serious head injury from the above scenario. This is assuming a young, healthy person. The part of the head that was struck would play into it though. The occiput (back of the head) and fronmtal area are pretty resistant to blunt force trauma. The side of the head, quite a bit less so due to a number of anatomic factors.
There are a couple of different kinds of brain injury. First, you can gross disruption of brain tissue from direct apllication of force - typically penetrating trauma or massive blunt trauma with gross disruption of the skull. The latter is pretty rare - I saw it once wherein it was conclusively demonstrated that a wrecking ball >>>>> a human head. These can cause instant death in most of the latter cases or a more or less severe injury in the case of penetration based on the exact mechanism and location of the injury. There can also be primary brain injury from shearing forces. This is often what happens in car accidents. Basically, the brain is damaged as it twists or recoils inside the skull due to translational forces. The forces needed to cause this kind of damage are quite high, especially when spread over a relativwely large area (e.g the tissue box).
Then there is a large variety of secondary brain injuries and delayed primary injuries. Things like bleeding into the cranial cavity (epidural or subdural hematome, etc.) and so on. The amount of force needed to produce these is quite variable, but from my experience I doubt the tissue box at 60mphh would pack enough punch. Lots of peope get beaned with a baseball at 60mph and while this can cause fatal injury, it usually does not. And a baseball has a lot more mass and delivers force over a much smaller area than a tissue box.
Rich
Zero_to_69
08-04-2005, 04:28 PM
Hey, you're not going to believe this, but I was making a sandwich just now
and saw a box of tissue on the table.
I picked it up and whipped it at the wall as hard as I could (try it, it's fun!).
I was standing about 10 ft. from the wall.
She goes pretty good!
I take back my last statement about directional stability. :cool:
LameRandomName
08-04-2005, 05:20 PM
There is also the issue of drag I suppose...
Using Bowling's Aerodynamic HP Calculator (V2.00) and assuming a Coefficient of drag similar to a tractor trailer with the following inputs:
Coefficient of drag = 1.2
Frontal Area = 0.33 sq feet
Test Temperature = 70.00 degrees F
Test Barometer = 30.00 inches Hg
Vehiche MPH = 60
That gives us the following results:
Air Density Computed is 0.00233
Aerodynamic "Drag Factor" is 0.00099
Rolling "Drag Factor" is 14.22689
Computed Aerodynamic Horsepower Required is 1
Computed Rolling Horsepower Required is 0
Computed Frontal Lift Force is 0 Lbs.
Of course, I don't have the slightest idea what all that means, but it sure looks groovy. :D
OldSStroker
08-04-2005, 05:44 PM
Rich,
Very interesting info, well maybe with the exception of the wrecking ball/head impact thing. In the days before airbags, a lot of automobile testing was done on head impact on instrument panels, top of steering wheel and anything a belted or unbelted body would hit in a frontal vehicle impact. Here the head, which has the approximate mass of a bowling ball if I recall correctly, was the projectile hitting the inside parts of the vehicle.
When the vehicle hits something head on, it stops but the occupants continue on at the initial vehicle velocity. The inside of the vehicle effectively backs into the passenger. This is where restraints and airbags help. It's this "secondary collision" that does the damage.
The forces are much larger than most people imagine. Passenger vehicle seat belts resist at least 5000 lbs of force before they fail, but some crashes are so violent that seat belts fail in tension. Of course, at that kind of deceleration (load) the crash is probably not survivable anyhow. Racing seat belts are much stronger.
I wish I could have gotten past the "blood & guts thing". Medicine interested me greatly. Never could get past it. My wife is a first assist for a general surgeon. She likes to watch surgery on TV while eating. I can't even watch it with no food in sight. The day's cases are not dinner conversation, needless to say. Trauma seems to me to be the worst case.
So, baseball caps (but not baseballs nor bats) and Kleenex boxes are ok on your rear package shelf, but bricks, bowling balls, and Dominion head castings aren't.
Come to think of it, I've never seen a box of Kleenex used as the fatal weapon in a Law and Order episode. :)
MachinistOne
08-04-2005, 09:31 PM
I'm an EMT in this county and we don't work patients in extreame car accidents( 60mph into tree ->unresponsive, no pulse) because even though they can look fine from the outside, the secondary collision as you put it will most likely break organs off inside the body especially snaping the aorta it doesn't sound right but that's the SOP.
number77
08-04-2005, 10:51 PM
Oddly enough, I'm currently considering going to med school (i would like to be a trauma surgeon), just because I don't like seeing people like that.
So your just saying you don't resuscitate them?
OldSStroker
08-05-2005, 05:25 PM
My favorite trauma surgeon got his start in VietNam (we're both in our early 60's). He is very laid back. IOW, he never panics in any situation. He is very fast at what he does; less time = more survivors. He doesn't mind getting calls at all hours, especially weekend, holiday or full moon nights, and it's almost always nights.
He doesn't save all of them. If the trauma surgeon is working on them, they are hurt badly. Some are very young, and were perfectly healthy until the trauma. That's the tough part.
If you have these characteristics and can juggle a number of balls simultaneously (figuratively speaking), trauma might be just the ticket for you.
My analogy of surgery to flying: trauma surgery is more like driving a fighter than a commercial transport. Transport pilots get rich, but bored, with a few exceptions. (Toronto in a T-storm).
My $.02
unstable bob
08-06-2005, 02:32 AM
Funny you should mention the Dominion head casting as being a "no-no" on the rear package shelf. I was able to test that theory w/o having that beret wearing woo-woo or his metrosexual side kick around at all! I hauled one of my heads around for a long time on the package shelf of an 86 Cutless. And one day I was passing Joey's Dog House, and noticed a sign out front that said "Under new management! Special 2 day: 2 for 1 chilli dogs!" Well, I slammed on my brakes so I could bang a quick "u-ey" to get some of those dogs,and 'sho 'nuff...the Dom head flew forward like a cruise {night} missile!
It wailed me in the back of my dome, and then fell to the floor. The only damage was a small chunk broke off the corner of the head. The Dominion head, not my head. So, I guess yer theory is 50/50 Pops! If you are unstable bob gable, it is safe to ride around with a Dominion head on yer package shelf. If you ain't unstable bob, you shouldn't try it at home!
SABLT194
08-06-2005, 05:53 AM
Someone's got far too much time on their hands! :eek:
rskrause
08-06-2005, 08:27 AM
That is one great post, thanks for the laugh! Did you sell those {in}famous heads or what? I think I recall hearing that you did?
"Resuscitation" is not "reanimation". Dead is dead in medicine (or pre-hospital care) with a couple of specific exceptions. TV and other media have created a lot of misconceptions in this area. It's gotten to the point where we sometimes engage in futile resuscitation efforts so we can tell the family "we did everything" but were not successful. This is a pointless waste of resources which is dangerous to the staff (blood and body fluid exposures are common in these circumstances) and therefore unethical. It really amounts to assaulting a dead body and then lying to the family about what we did and why. But it has become common practice. The motivation, at least, is largely benign in that we hope it will comfort the family, but the fact that it is necessary reflects the darker motivations of "defensive medicine" and the eroding faith of people in physicians (and in other professionals) that can be laid largely at the feet of plaintiff's lawyers.
Rich
OldSStroker
08-06-2005, 08:49 AM
Rich
UB is still the "owner of record", Rich but he has consigned them for some reconstructive surgery. That prompted my reference. ;)
BTW, UB is a hoot! Cool guy also.
Defensive medicine as you described it bothers me. I don't even want to know how high the premiums are on malpactice insurance for cutters.
LameRandomName
08-06-2005, 10:08 AM
For some reason this put in mind of some oddities I have seen in regards to how much damage a person can absorb and still function, if only for limited time.
I'm speaking specifically of bullet trauma.
I'm not the first one to observe this and I wont be the last, but it still fascinates me the way one guy can receive a non-life threatening hit in an extremity and drop like a marionette with cut strings, never to move again; while another guy can soak up lead like Rosie O’Donnell sucking up popcorn shrimp at a seafood buffet, but keep functioning long after they should have stopped.
Obviously there's a psychological component involved, but still...
It can be pretty damn odd.
Another incident, which I didn't personally see but which occurred when I was stationed there; was a guy at Ft Riley Kansas who got run over by a tracked vehicle. Kid was sleeping on the ground, which was kind of soft because of the rain we had been getting, and got run over from feet to (almost) head. The track actually rolled off his shoulder, just missing his melon.
A friend of mine who was a medic saw him at the hospital and said it was the most bizarre thing he's ever seen. First of all, the whites of his eyes had gone mostly red, but more startling was the way he had turned "African-American"
He had what for all practical purposes was a Full Body Bruise.
My friend said that it was due to capillaries being burst from the pressure.
I don't know...
My specialty at the time was blowing things up, not medicine.
Point is, the human body seems to be simultaneously incredibly resilient and astonishingly fragile.
number77
08-06-2005, 05:39 PM
About 8 years ago, a friend of mines father was in the military. I was friends with his son, who told me that someone had purposely pushed someone else down in front of a tank (knowing they wouldn't be hurt), and it ran them over, but because the mud was right, they just sunk into the ground and the tank passed over them. I didn't know what to think of it (it sort of made sense), but now i know it is possible.
Randy Molkentine
08-06-2005, 09:14 PM
That seems like a real intelligent thing for someone to do in the military. I know a tank generates a huge footprint with its tread but "knowing they wouldn't be hurt" doesn't seem possible when you are dealing with running someone over with a tank! ;) Better hope there isn't a submerged log and the mud is the perfect consistancy. Might be "possible" but I bet it would end in death most of the time!
number77
08-16-2005, 06:39 AM
Well...I think he mentioned them doing it to two guys...so I guess that goes from possible, to not very probable.
Back on track though, in the experiment they showed on tv, it involved towing a very light weight trailer and having it hook to something, or hit something to make it stop. My issue is that they used a piece of wood to see if it would go through that (they may of had some foam also). But the point is, is that it was flat so that the objects being thrown at them have no choice but to hit them. In an car crash, if you were hit in the head by something, your head would be able to move to a certain extent. even if your head didn't move, your heads shape could allow a sort of deflection of some off the objects force off to the side. and a third thing is that if the object (klenex box, bowling ball, etc.) is flying forward in a crash, so would you. If you were wearing a shoulder seatbelt, your head would fly towards the stearing wheel of the car, in the natural bending motion, going forward and down. This would all for some clearance for whatever object to fly over your head (assuming you don't have headrests in this car), or at least allow the object to deflect more (more than if you were sitting up right).
jerminator96
08-17-2005, 11:56 AM
A note on the amazing and almost freakish capabilities of the human body:
A good friend of mine served numerous tours of duty in vietnam with the USMC. His job was manning a .50cal gun on one of the "walls" of their camp. Once while their base was being attacked he claimed that a VC soldier was moving toward him while he sprayed the man with bullets until he could actually see through him. My friend stopped firing in amazement and the VC actually got so close that he was about to impale him with his bayonet until a blast from a shotgun took his head clean off his shoulders.
Maybe true, or maybe just too much acid in the 70's. Certainly a cool story though.
OldSStroker
08-17-2005, 02:49 PM
Are you sure it wasn't a Kleenex box that got the VC?
I've heard those 70's acidheads are now TV producers. ;)
