Turbo Installed
viper03af
08-03-2005, 06:04 PM
FINALLY turbo is installed
it pulls VARY hard with the biult motor !!! :bow:
www.turbov6camaro.com/turbo
Need4Camaro
08-03-2005, 06:52 PM
Jesus those photos are WAY to huge to make anything out...
But congrats... I can bet you're peeling out every corner now ;) Any Dyno or estimated numbers? How much PSI are you running? What kind of motor work done? Also didn't you run NOS? I could have sworn you ran NOS...
Edit: What happened to the nose of your car?
viper03af
08-03-2005, 08:55 PM
Edit: What happened to the nose of your car?well the maf max's at 10 psi or ~350 RWHP on our car. so not obave that till i go SD or till recal the MAF or get a Mega Squirt system....
right now i'm ruuning about 7 psi but its no holding there got to trouble shoot that (keeps goign to 10 PSI)
don't have to be on corner to peel out the tires break loos at the top of the RPM range.
www.turbov6camaro.com/mod.html <<< mods
NO NOS
MustangEater82
08-04-2005, 01:44 AM
Congrats... get that thing working... If I were you I'd see about getting in touch with Art Hansen for some help. And see if he can work anything with the MAF problem.
think you'll get your 10.99 this fall?
I am hoping for my 13.99 this fall... full interior, internally stock motor. :)
viper03af
08-04-2005, 05:58 PM
not unless i find 4-6k laying on the ground for tranny and rear and drags :(
Need4Camaro
08-04-2005, 06:01 PM
How streetable is your car now? I mean can you baby it without breaking things or is it completely unusable in this form?
viper03af
08-04-2005, 06:15 PM
well WOT and nothing borke but the tires so far :D
and my gas gauge is sinking FAST
but i'm maxing the maf and all other cars that have maxed the maf are at 330-348 RWHP
so i havn't broken any bounderies ...................yet
its the only car i have, only thing new is i have to turn it off when ordering food cause they can't hear me lol
MustangEater82
08-04-2005, 07:08 PM
Just run it... if you cruie the f-body boards you can find 10-bolts for cheap...
besides you can put in 10 10 bolts for cheaper then putting in a 12-bolt.
just stick with lt1 driveshaft as for the tranny, if you figure that out, send me a e-mail, thats what got me to sell my wet kit before I installed it.
viper03af
08-04-2005, 08:14 PM
i know whos goign to biuld my tranny
Need4Camaro
08-05-2005, 02:02 PM
Was curious but wouldn't a LS1 Aluminum DS be better?
jonathan_abilene
08-12-2005, 03:56 AM
probably, unless you snapped it and pole vaulted at 100mph down the drag
great turbo!
if your boost accidently climbs 3+ psi to 10psi boost, you might want to shoot more fuel in eh?
MustangEater82
08-12-2005, 04:30 AM
Its lighter so better for performance...
but steel is stronger then aluminum. More likely to break a aluminum.
Need4Camaro
08-26-2005, 02:21 PM
true but LS1's are putting out close to what he's putting out plain stock and arn't anywear near breaking driveshafts... It would take one HELL of a V6 to snap one...
Tru2Chevy
08-26-2005, 02:31 PM
Stock or very close to stock M6 LS1s have busted driveshafts with slicks....
- Justin
deadmeat2004
08-26-2005, 04:18 PM
need vids!! that work!
viper03af
08-26-2005, 11:50 PM
lol try the vid now
it should work now, i change over my webpage to a better sever lol......
err the max was maxing at 8-9 psi :eek:
i have that fixed now and i did hit 12 psi only one time to test it...
the fuel pump is installed and i have 2 bugs to get out before i put the 10 psi spring back and go balls to the back seat.......
i don't see any problems with 550 RWHP :eek: :eek: :D
mainly cause at 12 psi i was still under 11.0:1 on the WB O2 and at 7 psi there is no knock at all and i did not pull any timing yet.......
i did add some fuel in a few spots but that is about it the turbo spools fast and at 3200 the WB saw 11.7 so i added some fuel there....
the car is still vary street able the tranny is fine (so far) (i think the lanches kill em)
it still open exuahst and it not really that bad.......
1 down fall
14.5 MPG CITY and boosting ALOT !!!!!!!!!!!!..... i mean ALOT
www.turbov6camaro.com/tuning << my log of 6.4 to 6.8 psi runs
Need4Camaro
08-27-2005, 10:25 AM
vid still doesn't work...
but 14.5 MPG? 500+ RWHP??? I'd take it!!! :D
