Uprated Duramax; Allison becomes a 6 speed
Old Aug 1, 2005 | 10:53 AM
96_Camaro_B4C's Avatar
2006 Duramax 6600 Turbodiesel to Deliver Class-leading Torque in a More Powerful and Refined Package
Engine output for Chevy Silverado HD and GMC Sierra HD increased to 360 horsepower and a class-leading 650 lb-ft of torque
Significant updates result in smoother, more refined operation, as well as reduced emissions
New glow-plugs reduce start time by as much as 50 percent
PONTIAC , MICH. – Later this year, GM Powertrain will introduce a new 6.6L Duramax 6600 turbodiesel V-8 (RPO LBZ) for the 2006 model year Chevy Silverado HD and GMC Sierra HD with class-leading horsepower – 360 (268 kw) at 3200 rpm and class-leading torque, at 650 lb.-ft. (881 Nm) at 1600 rpm. In addition to the power increase in the Silverado and Sierra, all 2006 Duramax engines have been significantly revised to deliver lower emissions and significantly improved quietness and smoothness in every application.
The 2006 Silverado HD and Sierra HD with the Allison 6-speed automatic transmission will be equipped with a significantly revised 310 horsepower Duramax 6600 (LLY) through the third quarter of 2005. It will be replaced in these applications in the fourth quarter of 2005, by the higher output, 360-horsepower Duramax (LBZ).
“The introduction of the Duramax diesel in 2001 represented a significant evolution in North American diesel pick-up truck market and propelled GM’s heavy duty diesel pick-up truck market share to over 25 percentage points,” said Charles Freese, GM Powertrain executive director, diesel engineering. “The introduction of the improved, 2006 Duramax turbo diesel once again sets a new benchmark to which all others will be measured.”
The Duramax 6600’s horsepower and torque increase and emissions reduction are enabled by a strengthened iron cylinder block and a lower compression ratio. The lower compression reduces stress on the engine by reducing the peak cylinder firing pressure. This, in turn, allows more fuel to be burned – more fuel means more power – while the lower compression helps reduce NOx emissions. Lower compression also helps reduce noise and vibration, making the all variants of the 6600 a quieter and smoother engine.
A revised variable-geometry turbocharger also enhances the driving experience of the Duramax 6600. Aerodynamic changes to the turbo’s vanes help tailor controlled application of turbo power for seamless and immediate response at full throttle. The turbo, which spins at up to 120,000 rpm, is high-speed-balanced, reducing vibration and resonance – and contributing to the engine’s overall smoothness and refinement. The revised turbo also helps reduce emissions, while maximum boost remains at 20 psi.
Another new feature of the Duramax 6600’s turbo system is the capability of the variable-geometry turbocharger to provide exhaust braking. This function is available on some medium-duty truck models and can replace add-on exhaust brake hardware. With the new system, braking is controlled by a signal from the engine controller and can be activated by the driver.
The comprehensive list of changes and upgrades to the 2006 Duramax 6600 includes:
Cylinder block casting and machining changes strengthen the bottom of the cylinder bores to support increased horsepower and torque
Upgraded main bearing material increases durability
Revised piston design helps lower compression ratio to 16.8:1 from 17.5:1
Piston pin bore diameter increased for increased strength
Connecting rod “ I ” section is thicker for increased strength
Cylinder heads revised to accommodate lower compression and reduced cylinder firing pressure
Maximum injection pressure increased from 23,000 psi to more than 26,000 psi
Fuel delivered via higher-pressure pump, fuel rails, distribution lines and all-new, seven-hole fuel injectors
Fuel injectors spray directly onto glow plugs, providing faster, better-quality starts and more complete cold-start combustion for reduced emissions
Improved glow plugs heat up faster through an independent controller
Revised variable-geometry turbocharger is aerodynamically more efficient to help deliver smooth and immediate response and lower emissions
Air induction system re-tuned to enhance quietness
EGR has larger cooler to bring more exhaust into the system
First application of new, 32-bit E35 controller, which adjusts and compensates for the fuel flow to bolster efficiency and reduce emissions
The Duramax 6600 also has a new intake air heater to reduce smoke and emissions during cold or light-load driving. The system features a 1000-watt grid heater located in the air intake duct, which is triggered automatically by the engine controller. It heats up the incoming air to speed warm-up of the engine.
In addition to 50 more horsepower and 45 more lb-ft of torque in the Silverado and Sierra, changes to the 2006 Duramax 6600 build on a host of improvements introduced for ’05 – improvements that bolstered an already strong foundation. The Duramax 6600 features a rigid cast iron cylinder block with induction-hardened cylinder bores; four-bolt, cross-drilled main bearing caps; forged steel, nitride-hardened crankshaft; aluminum pistons with jet-spray oil cooling; aluminum cylinder heads with four valves per cylinder; integrated oil cooler and a charge-cooled turbocharging system. Features, such as easy-access fuel filter and timing gears, reduce maintenance time and effort.
A new, 32-bit E35 engine controller monitors and adjusts the engine’s operation. Designed exclusively for the Duramax diesel engine, the controller helps the injectors precisely meter fuel to the cylinders and can compensate for the variability of the injectors and fuel flow. This sophisticated, more powerful controller also can support up to five injections per cylinder and eliminates the need for an engine-mounted drive unit to fire the fuel injectors.
The new Duramax 6600 in the Silverado and Sierra heavy-duty pick-ups will be available exclusively with the new Allison 1000 6-speed automatic transmission, featuring class-first features, like tap-shift range selection mode.
In addition to the Chevy Silverado HD and GMC Sierra HD, the Duramax 6600 (LLY) is also available at varying power outputs in the Hummer H1 Alpha, Chevy Kodiak and GMC Topkick. For 2006, the Duramax is available for the first time in GM’s full-size vans, Chevy Express and GMC Savana, providing power and capabilities matched with quietness and smoothness not found in competitors’ diesel-equipped vans.
The Duramax 6600 was introduced in 2001 and was developed in a partnership with GM Powertrain and Isuzu Motors. Since its introduction, more than 650,000 6.6L Duramax diesels have been built and sold.
The Duramax 6600 is assembled at the DMAX facility in Moraine, Ohio , a joint venture between General Motors and Isuzu created specifically to produce diesel engines.
I've driven a couple of trucks with this combo, and it is BADASS. In a regular cab, 2wd 2500 HD, it would almost be scary. It feels like it could yank your house off its foundation.
Sorry for the long post, but I figured some might be interested.
Old Aug 1, 2005 | 11:00 AM
Big Als Z's Avatar
Re: Uprated Duramax; Allison becomes a 6 speed
650ftlbs?!?!?!?! GOOD LAWD thats a lot of torque.
Old Aug 1, 2005 | 11:05 AM
ImportedRoomate's Avatar
I was wondering when that 6 speed would be announced.
Here's and informative pdf about it:
http://www.lubricationspecialist.com/allison06.pdf
Nice to see the Express and Savana getting the Duramax. Now what about the Suburban and maybe even Tahoe?
Old Aug 1, 2005 | 11:18 AM
PacerX's Avatar
Heh...
"Titan" is a downright funny name in light of specifications like these.
I could see this combo in a Suburban or Tahoe, but I'm guessing the volume would be very, very low.
Old Aug 1, 2005 | 11:23 AM
305fan's Avatar
wow
Now they need to get the duramax (or a smaller version) in 1/2 tons, Suburbabns and Tahoes. Maybe the GMT-900 will offer diesle half tons
Old Aug 1, 2005 | 12:00 PM
HAZ-Matt's Avatar
They need to put a variable geometry turbo on the Solstice.
Old Aug 2, 2005 | 12:22 AM
Eric Bryant's Avatar
Only because it'd only be offered in the 3/4-ton version of the Suburban, which is not very popular. If anyone would drop a decent diesel into a mainstream SUV, I think it'd really sell. GM now offers the 'max in the G-vans, but only with the 4L80E trans so it's detuned quite dramatically. They'll still sell a lot of them.
Those new Duramax specs are amazing. I like the idea of a 2nd overdrive on the Allison as well; it should be interesting to see what GM does with the axle ratio on vehicles equipped with that combination. The extra power + a lower final-drive ratio should make for some "spirited" performance, if GM pops some 4.56s out back.
Old Aug 2, 2005 | 06:50 AM
305fan's Avatar
Well the Corvettes going 6 speed auto and it has 2.56s in the rear.
I don't think 4.56s are needed they are too deep. The 6th gear overdrive proably isn't low enough (numericaly) but the first gear probably is really high numericaly) that way your rear end does not have to be a high ratio.
New Corvette 1st gear is somthing like 4.16 X 2.56 rear axle= 10.64 to 1
Old Aug 2, 2005 | 10:32 PM
The first 5 gear ratios are still the same, with the 6th being a second OD ratio. That should allow deeper gears - at least 4.10s. Note that the Ford Super Duty with the Powerstroke and the Tow Boss package gets 4.56 gears out back.
Old Aug 2, 2005 | 10:38 PM
305fan's Avatar
ah my mistake. I assumed the first gear would be alot higher (like the Corvettes or close)--but your right.
Old Aug 3, 2005 | 03:59 PM
ryan1488's Avatar
i actually build those things for a living, and we have really been busting butt ever since we switched to 06s.
AWYEE
Parts Wanted
May 12, 2015 06:58 PM
4586
Apr 27, 2015 06:08 AM
njspder
Middle Atlantic
Mar 5, 2015 05:39 AM
sdn1997rs
Dec 30, 2014 08:30 AM
