What size bolt for the steering linkage? *pic*
Old Jul 31, 2005 | 07:23 PM
Black1995Z's Avatar
Arrow What size bolt for the steering linkage? *pic*
Shoebox you've been pretty good at these questions
http://members.***.net/duperre/steering.jpg
Anyone know the size?
Old Jul 31, 2005 | 10:16 PM
Re: What size bolt for the steering linkage? *pic*
M10 x 1.5 x 39
GM PART # 26030302
Old Jul 31, 2005 | 11:24 PM
Black1995Z's Avatar
Saved my *** again, thanks Rob!
Does it have a nut at the other end or is it just a bolt?
Old Jul 31, 2005 | 11:49 PM
Bawls's Avatar
It's just a bolt. If ya look on the other end where the bolt goes through, you'll see it's threaded.
Old Aug 1, 2005 | 01:52 AM
Black1995Z's Avatar
Damn, I have a bigger problem. I cant get them together. Is there a trick or a tool? There isnt enough slack to slide it in to put the bolt through.
Old Aug 1, 2005 | 02:00 AM
Bawls's Avatar
Do what? You put the top of the linkage over the shaft first, all the way up, then slide the bottom of the linkage over the steering rack shaft.
Old Aug 1, 2005 | 02:32 AM
Black1995Z's Avatar
It doesnt want to slide in, Ive tried moving it around and I cant get it to slide in...
Possibly if I beat on it at the right angle with a hammer...
I have another ? for you...
Do the threads need to be on the top side or the bottom? The steering wheel is centered/straight.
*edit: I think its supposed to be down
Old Aug 1, 2005 | 11:04 AM
Bawls's Avatar
Threads need to be down. With the wheel straight and the tires straight, you should be able to access both bolts from the top.
Old Aug 1, 2005 | 01:29 PM
Z28barnett's Avatar
The rack stub has a half round cut out in it. You have to have the base of the lower u joint turned so the through hole for the bolt lines up with the cut out in the rack stub shaft. It will not pass though until you get this lined up.
Take your fingers and check the stub shaft and you will feel the notch.
Z28
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Jan 11, 2015 03:47 PM
