95' Camaro 3.4l NEED HELP PLZ ! Knocked Something off the oil filter assemely ???
Spllouder
07-30-2005, 05:53 PM
ok today it changed my oil filter from the top on my 1995 camaro 3.4l v6 and i knocked something off looks like a sensor or something has a wire on one end and is in a rubber plug and just sits on the oil filter assemely . now i have no oil pressure and oil is leaking for yje hole this sensor was in .
What is it ? how do i fix it ?
Thank you
Jason T.
crasher88
07-31-2005, 12:12 AM
thats your oil pressure sending unit. Never messed with mine on my 94 3.4 but if its already off just go buy a new one and replace it. You might wanna do a quick search around the borad as to how they are supose to attach onto the oil filter housing.
Spllouder
07-31-2005, 02:55 PM
yep it was the oil pressure switch / send unit . the plactic just camapart around the nut flange , when i bumped it , needed to be replace anyways , if that think would of broke of during the car was running you woul lose alot of oil fast .
looks easy to repair just a open end wrench will do it .
Thak you
atl2001
08-01-2005, 01:40 AM
but its a pain to get a wrench on it.. trust me ;) (note, dropping a header on the sensor will snap it like a twig)
MarcR94v6
08-01-2005, 06:35 PM
So how much alike does the oil pressure sending unit look like the O2 sensors? What was described sounds like what I thought were O2 sensors, one on either side of the car threaded into the exhaust manifolds. Am I mistaken, or is one of those single wired sensors for the oil pressure??
atl2001
08-02-2005, 12:03 PM
they are about the same shape and size, but he took out the oil pressure switch, missing an O2 wouldnt spew oil out of the motor. he is talking about the sensor right above and a little twards the front of the car ( go look, you have one too)
