So my choke wasn't hooked up...
IRONFIST
07-27-2005, 10:11 PM
My car used to run a little rich, and I just noticed my electric choke wasn't set up properly. (the coil wasn't lined up proplery and the choke was always "open").
Now that I fixed it... the car just floods from the start :confused:
The carb I'm using is an Edelbrock 750 performer, electric choke. Any ideas?
talos
07-28-2005, 01:58 AM
maybe this is just a shot in the blue, but was the carb box tune? or was it tuned well the Choke wasn't working. Therefore it needing to be retuned to compisate(sp?) for the choke now working?
IRONFIST
07-28-2005, 11:36 PM
The carb was tuned with the choke not working. But it was running rich. Now that I set the carb up properly, with the choke I mean it still is running rich at idle. Seems like the idle screws make no difference at all.
I got no idea what to do :confused:
Z28SORR
07-29-2005, 02:31 AM
To start with the carb is adjusted with the engine at operating temps. So the coke would be fully open. If the idle mixture screws have no effect on the idle it is usually an indictation of other problems. Like vacuum leaks, etc.
I know this is sacrilege but you may want to buy a BOOK on tuning these carbs.
IRONFIST
07-29-2005, 03:28 PM
Actually my local speed shop has photocopies of the Edelbrock tuning manual. Turned out my step up springs were too weak for the amount of vacuum I was running...
Causeing a rich condition.
Fixed that, now onto other things... :cool:
If anyone finds this in the archives, here are a few useful sites
http://www.edelbrock.com/automotive/eps_intro.html#contents
http://www.carcraft.com/techarticles/1071/
angel71rs
08-01-2005, 04:19 PM
Qjets use the same arrangement, except they are called power piston springs. I ran a qjet on a 442 once just for grins. I did the low buck tune on the spring by clipping 1/2 turns on the spring till piston stayed down at idle w/low vacuum that came courtesy of a W31 cam I installed.
